Problem creating a "solid object" (.3dm model attached)
 1-3  4-23
11701.4 In reply to 11701.2
Hi Frederik, also another way you could close this would be to slice off the end with a line so you have a planar opening. Then select the object and run Construct > Planar to fill in the planar ends.
I've attached a version with that done.
11701.5 In reply to 11701.3
Hi Barry,
Many thanks for helping me out with the model! I'm trying to re-create what you did, just to make sure I understand how it works. Does this sound about right? (And of course, anyone else is welcome to jump in and help too!)
I've attached my clean 3DM curves again.
1. I offset the profile curve at the top, so now I have both an inner and an outer profile curve.
2. Then I Sweep each of these profile curves using the same two rail curves (see vertical ones in my screenshot).
3. That gives me both an outer and an inner surface — with or without Caps on the ends.
3a. If I enable "Cap Ends", then Moi3D only adds a Cap at the top. The bottom is still open. Is there a way to cap both ends automatically?
3b. Maybe related to the above, but I can't seem to manually cap the bottom hole after the Sweep. Any idea why?
4. I noticed you added those double lines at the bottom. How were they used in your process?
5. And from here I'm kind of stuck again.
Size: 109.2 KB, Downloaded: 129 times, Dimensions: 675x529px
Size: 130.6 KB, Downloaded: 132 times, Dimensions: 755x484px
Size: 112.4 KB, Downloaded: 118 times, Dimensions: 675x540px
Size: 140.1 KB, Downloaded: 125 times, Dimensions: 772x601px
Size: 130.6 KB, Downloaded: 118 times, Dimensions: 800x554px
11701.6 In reply to 11701.5
Hi Frederik, there is a little issue with the rails, they are made up of multiple segments that are just a couple of degrees off from being smooth.
But even without tuning that up I can't seem to repeat the bottom cap failing over here.
Here's what I'm doing, using the v5 beta (https://moi3d.com/beta.htm):
I select the outer curve:
Run Construct > Sweep and pick these as the rails:
That makes this result:
I then repeated that with the inner profile which made a second solid and then boolean differenced them to get the attached model.
Maybe the sharp point in the rails is having some strange effect, I'll post a tuned version of that in a moment.
11701.7 In reply to 11701.5
Hi Fredrick,
Your process is correct only I had outer and inner as solids ie with capped ends.
The fact you showed the bottom thickness as 4mm and the side walls as 3mm was the reason for making an inner.
So the 2 lines at the bottom are showing the bottom angle and then offset 4mm this line is used to Boolean difference the inner to give the bottom 4mm thickness.
Boolean difference inner from outer and you have your part.
Hope that’s helpful
Cheers Barry
11701.8 In reply to 11701.5
Hi Fredrick, here is a version with the rails fully smooth, does it behave better for you?
11701.9
Hey again,
I think I’ve solved the first problems now! Turns out my inner profile curve had fewer points than the outer one. So instead, I offset the inner curve to create the outer — that way they matched. After that, I could run the Sweep operation, and I got caps on both ends. From there, it was easy to create the inner and outer solid surfaces, and then I used a Boolean to cut out the inner solid. So I guess the initial problem was the mismatch between the profile curves.
Now I’ve run into some new issues while adding fillets. See my screenshots!
1. I added a few more details to the model.
2. When I selected all the inner edges and applied a fillet, it seemed to work — but when I looked closer, the fillet corners don’t align properly.
3. I also noticed that the fillet on the outer top edge doesn’t match up with the side surface.
Could someone please take a look at my 3DM file again and help me figure out why this is happening? The file includes some layers (styles) showing the model in different stages.
Thanks again — really appreciate the help!
Size: 102.2 KB, Downloaded: 140 times, Dimensions: 800x735px
Size: 68.6 KB, Downloaded: 121 times, Dimensions: 800x611px
Size: 62.9 KB, Downloaded: 120 times, Dimensions: 800x628px
Size: 65.3 KB, Downloaded: 124 times, Dimensions: 941x560px
11701.10 In reply to 11701.7
Thanks Barry,
"So the 2 lines at the bottom are showing the bottom angle and then offset 4mm this line is used to Boolean difference the inner to give the bottom 4mm thickness."
I don't fully understand this part. I used the upper line (marked yellow in my screenshot) to Trim off 4mm from the inner Solid. Then I ran the Boolean Difference operation to create the thickness. Is there an easier way of using the lines when working with Booleans?
Size: 116.8 KB, Downloaded: 123 times, Dimensions: 800x518px
11701.11 In reply to 11701.9
Hi Frederick,
It shouldn't be that... Were you trying to use both the inner and outer profile curves in just one single sweep?
I'm having some difficulty finding the locations you show in your screenshots. Could you maybe save a separate file for each question with the view showing the area where you did the snapshot? It seems like the posted model is slightly different than the screenshots.
It's a normal thing for CAD fillets to have different widths where they meet up, it's how a "rolling ball" fillet functions. It's focused on keeping a constant radius value and it's only when all neighboring surfaces are at the same angle to each other that they will have the same widths.
So for example something like this:
When you fillet it, you will get a result like this which is how CAD fillets are intended to work:
If you include all edges that meet at a point then the fillet surfaces will still be like that but they will be cut back and have a corner juncture patch where they come together:
11701.12 In reply to 11701.8
Thank you so much for helping me figure this out! I'm not sure what was wrong with my original rail splines — how did you make them fully smooth?
I'm starting to understand how I can use different objects to build and cut surfaces... but I'm still running into some issues when adding fillets to my solid objects. See my latest posts for details.
11701.13 In reply to 11701.12
Hi Frederick,
I turned on their control points and used Transform > Align to make these points all exactly in line:
I posted a reply above, but I'm having a hard time finding the location that matches your screenshots.
Like where is this one for example:
I think I found your #1 which is a normal result and I thought your #2 is here but your screenshot has a sharp corner while the model has a juncture patch:
It kind of makes it hard to answer your questions when the file is different than your screenshot.
11701.14 In reply to 11701.11
Michael,
Thanks for explaining how CAD fillets work. I'm more used to polygon modeling, where I always expect bevels (fillets) to line up evenly. As long as the fillets I created are considered normal in CAD, that makes sense. I'll make sure to save separate 3DM files with the correct views for any future questions.
The only thing I still don’t understand is the fillet on the top outer edge of the model. It seems to align correctly in the Front view, but not in the Right view. I fixed it by cutting and deleting a portion of the outer side surface, then closing it off again using a Loft between the top fillet curve and the open curve on the bottom side.
I’ve attached a 3DM file with the camera focused on the problem area. It should match the screenshot I posted earlier.
Thanks again,
Frederik
Size: 63.1 KB, Downloaded: 127 times, Dimensions: 1000x397px
11701.15 In reply to 11701.14
Hi Frederick,
Looks like a cosmetic display artifact with the display mesher not generating enough triangles in that area to make it look nice.
The display mesher is focused on doing things fast, when you do an export the export mesher is more tuned towards higher quality.
So it's just something to ignore, it doesn't need to be fixed:
At export, it looks like this:
11701.16 In reply to 11701.14
For the fillet widths not matching, the fillet width is purely a function of the angle between the 2 surfaces being filleted:
When each of those is filleted with a radius 1 fillet, it will make this:
So each of those fillets is made up of a radius 1 arc but with a longer or shorter length of the arc:
11701.17 In reply to 11701.15
Thanks again, Michael — good to know! I'm making some progress now. There are still a few bumps, but I’m getting there.
Size: 200 KB, Downloaded: 128 times, Dimensions: 800x771px
11701.18 In reply to 11701.17
Hi again,
I've built a backplate for my holder, and now that I'm nearly finished, I feel like the base is a bit too long. Is it possible to just select and move "the lip" of the model, or is rebuilding the shape the only way to go?
I've attached the two 3DM models shown in the screenshots.
Frederik
Size: 203.7 KB, Downloaded: 130 times, Dimensions: 1024x691px
Size: 140.1 KB, Downloaded: 141 times, Dimensions: 800x571px
11701.19 In reply to 11701.18
Hi Frederik, in general it can be difficult to edit pieces by dragging when you've got fillets and shelling applied.
For your case here though you can use construction techniques to edit it - draw in a rectangle like this:
Select the object and run Construct > Boolean > Difference and then select the rectangle as the cutting object which will make this:
Drag the end piece over:
And then select both pieces and run Construct > Boolean > Union:
11701.20 In reply to 11701.18
For your blue object, it is possible to remove that edge using boolean union which will merge faces that are coplanar.
Select this face:
Use Edit > Separate to break it off as a separate object, then select the 2 pieces and run Construct > Boolean > Union.
Or another way - you could delete those 2 faces and prepare a selection like this and use Construct > Planar:
11701.21 In reply to 11701.20
That worked great — thanks for showing both of these techniques! I didn’t know that curves could be used for Booleans like that — I always thought it only worked with solid objects.
I used some Booleans to trim the rounded shapes, and I think that caused a lot of broken edges — tiny segments. I can join them, but whenever I separate the edges again, they split into all these little pieces.
Is there a way to merge or “Boolean” these edges together somehow, to get a cleaner model? It gets very tricky to apply a Fillet or Chamfer to these tiny bits. I’ve tried creating Closed Curves from the edge outlines, but I can’t seem to use them to generate a Fillet.
(New 3DM file attached)
Thanks again,
Frederik
EDITED: 10 Apr 2025 by FREDERIK
Size: 101.3 KB, Downloaded: 97 times, Dimensions: 578x522px
Size: 431.8 KB, Downloaded: 104 times, Dimensions: 800x745px
11701.22 In reply to 11701.21
Hi Frederik,
You can use the Merge command for that:
https://moi3d.com/4.0/docs/moi_command_reference10.htm#merge
Select the whole object, type the Tab key to put focus in the bottom XYZ input, then type Merge <enter> and those fragmented edges will be combined.
A curve is its own separate object, it isn't connected to the solid.
To make a fillet on the solid you need to select edges which are part of the solid, not separate curve objects.
11701.23 In reply to 11701.22
Thanks for explaining curves vs edges. I'm starting to understand the modeling process better. The Merge command worked great, thanks!
/ Frederik
Show messages:  1-3  4-23
