Problem creating a "solid object" (.3dm model attached)
 1  2-21  22-23
11701.22 In reply to 11701.21
Hi Frederik,
> Is there a way to merge or “Boolean” these edges together somehow, to get a cleaner model?
> It gets very tricky to apply a Fillet or Chamfer to these tiny bits.
You can use the Merge command for that:
https://moi3d.com/4.0/docs/moi_command_reference10.htm#merge
Select the whole object, type the Tab key to put focus in the bottom XYZ input, then type Merge <enter> and those fragmented edges will be combined.
> I’ve tried creating Closed Curves from the edge outlines, but I can’t seem to use them to generate a Fillet.
A curve is its own separate object, it isn't connected to the solid.
To make a fillet on the solid you need to select edges which are part of the solid, not separate curve objects.
11701.23 In reply to 11701.22
Thanks for explaining curves vs edges. I'm starting to understand the modeling process better. The Merge command worked great, thanks!
/ Frederik
Show messages:  1  2-21  22-23
