Problem creating a "solid object" (.3dm model attached)
 1-13  14-23
11701.14 In reply to 11701.11
Michael,
Thanks for explaining how CAD fillets work. I'm more used to polygon modeling, where I always expect bevels (fillets) to line up evenly. As long as the fillets I created are considered normal in CAD, that makes sense. I'll make sure to save separate 3DM files with the correct views for any future questions.
The only thing I still don’t understand is the fillet on the top outer edge of the model. It seems to align correctly in the Front view, but not in the Right view. I fixed it by cutting and deleting a portion of the outer side surface, then closing it off again using a Loft between the top fillet curve and the open curve on the bottom side.
I’ve attached a 3DM file with the camera focused on the problem area. It should match the screenshot I posted earlier.
Thanks again,
Frederik
Size: 63.1 KB, Downloaded: 127 times, Dimensions: 1000x397px
11701.15 In reply to 11701.14
Hi Frederick,
Looks like a cosmetic display artifact with the display mesher not generating enough triangles in that area to make it look nice.
The display mesher is focused on doing things fast, when you do an export the export mesher is more tuned towards higher quality.
So it's just something to ignore, it doesn't need to be fixed:
At export, it looks like this:
11701.16 In reply to 11701.14
For the fillet widths not matching, the fillet width is purely a function of the angle between the 2 surfaces being filleted:
When each of those is filleted with a radius 1 fillet, it will make this:
So each of those fillets is made up of a radius 1 arc but with a longer or shorter length of the arc:
11701.17 In reply to 11701.15
Thanks again, Michael — good to know! I'm making some progress now. There are still a few bumps, but I’m getting there.
Size: 200 KB, Downloaded: 128 times, Dimensions: 800x771px
11701.18 In reply to 11701.17
Hi again,
I've built a backplate for my holder, and now that I'm nearly finished, I feel like the base is a bit too long. Is it possible to just select and move "the lip" of the model, or is rebuilding the shape the only way to go?
I've attached the two 3DM models shown in the screenshots.
Frederik
Size: 203.7 KB, Downloaded: 130 times, Dimensions: 1024x691px
Size: 140.1 KB, Downloaded: 141 times, Dimensions: 800x571px
11701.19 In reply to 11701.18
Hi Frederik, in general it can be difficult to edit pieces by dragging when you've got fillets and shelling applied.
For your case here though you can use construction techniques to edit it - draw in a rectangle like this:
Select the object and run Construct > Boolean > Difference and then select the rectangle as the cutting object which will make this:
Drag the end piece over:
And then select both pieces and run Construct > Boolean > Union:
11701.20 In reply to 11701.18
For your blue object, it is possible to remove that edge using boolean union which will merge faces that are coplanar.
Select this face:
Use Edit > Separate to break it off as a separate object, then select the 2 pieces and run Construct > Boolean > Union.
Or another way - you could delete those 2 faces and prepare a selection like this and use Construct > Planar:
11701.21 In reply to 11701.20
That worked great — thanks for showing both of these techniques! I didn’t know that curves could be used for Booleans like that — I always thought it only worked with solid objects.
I used some Booleans to trim the rounded shapes, and I think that caused a lot of broken edges — tiny segments. I can join them, but whenever I separate the edges again, they split into all these little pieces.
Is there a way to merge or “Boolean” these edges together somehow, to get a cleaner model? It gets very tricky to apply a Fillet or Chamfer to these tiny bits. I’ve tried creating Closed Curves from the edge outlines, but I can’t seem to use them to generate a Fillet.
(New 3DM file attached)
Thanks again,
Frederik
EDITED: 10 Apr 2025 by FREDERIK
Size: 101.3 KB, Downloaded: 97 times, Dimensions: 578x522px
Size: 431.8 KB, Downloaded: 104 times, Dimensions: 800x745px
11701.22 In reply to 11701.21
Hi Frederik,
You can use the Merge command for that:
https://moi3d.com/4.0/docs/moi_command_reference10.htm#merge
Select the whole object, type the Tab key to put focus in the bottom XYZ input, then type Merge <enter> and those fragmented edges will be combined.
A curve is its own separate object, it isn't connected to the solid.
To make a fillet on the solid you need to select edges which are part of the solid, not separate curve objects.
11701.23 In reply to 11701.22
Thanks for explaining curves vs edges. I'm starting to understand the modeling process better. The Merge command worked great, thanks!
/ Frederik
Show messages:  1-13  14-23
