Not solid after boolean and clipboard question
All  1-2  3
11697.3 In reply to 11697.1
Hi Matadem, yes like Val says above your fillet radius is too large and there is an area with a messed up trim boundary here:
> also when you copy an item does it go to the windows clipboard?
With the Edit > Copy command or Ctrl+C / Cmd+C, yes.
> I tried it but my clipboard is empty and
What are you using to look at the clipboard?
> if it works can it be setup to be as an obj file onto the clipboard?
The .obj spec does not have anything in it about the clipboard, so it's not possible.
Show messages: All  1-2  3
