Nested Ellipses, and Ellipse Whirl
All  1-7  8-12
11695.8 In reply to 11695.7
Hi MO,
Thank you for the updated reset for Quartz.
Attaching the push button switch to reset input, with second terminal set to 1, and pushing the button, does the reset.
Node of whirl with (only) 4 child ellipses, range 90 to 180 degrees.
Over 180 degrees, they expand beyond parent ellipse0.
Tilt angle should be Modulus 180.
I'm not happy with behavior of Quartz.
I might try a script.
The axis RATIO is the same for all child ellipses. Just apply it to the widths and heights of the parent of the child.
Widths and heights get swapped every generation.
Ellipse[i] is the parent of child[i+1]
Ellipse[0] could also rotate, as the child of ellipse[-1]
Ellipse[i,j] could use j as the scaling index...
The step angles of a scaling ellipse for child 2 is twice that of child 1.
The step angles of scaling child ellipse 3, is 3 times that of child 1.
EDITED: 11 Apr 2025 by BEMFARMER
11695.10
imgbox
11695.11 In reply to 11695.10
Nice colors.
I tried trimming, but Planar did not like slivers of arcs.
So maybe just make each ellipse a different planar style?
11695.12 In reply to 11695.11
Hi Brian.
re :
Yes, it is.
https://disk.yandex.ru/d/Edv9N_pxiNZH-A
Show messages: All  1-7  8-12
