Geometric Points at Polylines Extremities
By Michael Gibson
script:/* Create point at polyline ends */ var objs = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.isCurve ) { var all_lines = true; var segs = obj.getSubObjects(); for ( var j = 0; j < segs.length; ++j ) { if ( !segs.item(j).isLine ) { all_lines = false; break; } } if ( all_lines ) { for ( var j = 0; j < segs.length; ++j ) { var line = segs.item(j); var f = moi.command.createFactory('point'); f.setInput( 0, line.getEndPt() ); f.commit(); } } } }
script:/* Create point at polyline start & ends */ var objs = moi.geometryDatabase.getSelectedObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.isCurve ) { var all_lines = true; var segs = obj.getSubObjects(); for ( var j = 0; j < segs.length; ++j ) { if ( !segs.item(j).isLine ) { all_lines = false; break; } } if ( all_lines ) { for ( var j = 0; j < segs.length; ++j ) { var line = segs.item(j); var f = moi.command.createFactory('point'); f.setInput( 0, line.getEndPt() ); f.commit(); if ( j == 0 &&!segs.item(j).isClosed ) { var f2 = moi.command.createFactory('point'); f2.setInput( 0, line.getStartPt() ); f2.commit(); } } } } }
My Moi French Site
11691.2 In reply to 11691.1
Hi PILOU,
More examples please :-)
11691.3 In reply to 11691.2
@ Psygorn
Of course :)
It can be used for make a "ghost volume", "ghost surface"...etc only by points...
Of course you can hide the Polylines
Then free to you to draw any objects on these points! ;)
By Copy to Points by Michael or _Vclone By Max Smirnov
Then free to you to use any render or better & funny some AI ;)
Here the free Vizcom with just an image, but you can also import inside a 3D file! .fbx / .glb / .obj (accepts NGons from Moi! )
Pearl bracelet 100 % influence (Ps I have forgotten to hide edges before the snapshot image! ;)
Organic Architecture 100 % influence
Organic Architecture 60 % influence
Organic Architecture 50 % influence
EDITED: 6 Apr 2025 by PILOU
