OBJ export broken for 3dm files made in old MoI versions.
All  1-3  4-8
1169.4 In reply to 1169.3
wow! thanks for the very prompt response :) I really appreciate it!
1169.5 In reply to 1169.2
Changing the ini file according to your instructions fixed the problem! Thank you very much! As I said before, it was only a problem when exporting older files made in old betas. Exporting new 3dm files does not create this problem, thank you again!
1169.6 In reply to 1169.5
Hi Chris, I have posted a patch for this problem here: http://moi3d.com/beta/Nov18_patch1.zip
To install the patch, unzip it and copy the new moi_lib.dll file over top of your old version in
C:\Program Files\MoI beta Nov-18-2007\
With this in place, you should be able to switch the .ini file back to:
CentroidTriangulation=y
So that you get the better triangulation with skinny triangle reduction, but with proper UVs.
Since you have a good sample model that reproduced the problem, could you please give the patch a test with the .ini file back to its original value to make sure that the bug is solved?
Thanks!
1169.7 In reply to 1169.6
the patch is just change the possibility
or it makes other things?
1169.8 In reply to 1169.7
Hi Pilou, this patch only fixes the triangulation bug that was creating improper UV coordinates in certain circumstances, nothing else.
I still have a few other things that I want to add before V1 final, so there should be another patch or another beta (not sure which) before the final launch.
Show messages: All  1-3  4-8
