Feature you coded for me doesn't work in V5
All  1-6  7-8
11688.7 In reply to 11688.6
Hi Frederick,
> Is there any way to bypass the asking and simply default to STL?
Yup, in ExportParts.js find line 22 that has this:
if ( WaitForDialogDone() ) DoExportParts(objectpicker.objects);
and change it to this:
/*if ( WaitForDialogDone() )*/ DoExportParts(objectpicker.objects);
That will bypass the asking stage and go immediately to the exporting.
Then to make it use .stl format find line 29 which has this:
var d = moi.ui.commandUI['extension'].value;
var d = '.stl'; /*moi.ui.commandUI['extension'].value;*/
That will make it always use STL format instead of getting it from the UI control.
11688.8 In reply to 11688.7
I can handle that.
I even understand most of it.
Frederick
Show messages: All  1-6  7-8
