Feature you coded for me doesn't work in V5
All  1  2-8
11688.2 In reply to 11688.1
Hi Frederick, can you please attach the plugin files here?
11688.3 In reply to 11688.2
Well that was stupid on my part.
I should learn not to rush.
There were three versions over the years.
#3 is the most recent and what I had been using successfully in V4.
Frederick
EDITED: 26 Mar 2025 by FCWILT
11688.4 In reply to 11688.3
Hi Frederick, is it that you want to have some child objects of a group selected and found by the script to export?
Does it work ok if you remove line #12 which has this? :
	objectpicker.allowTopLevelObjects();
Or you could also change this to:
	objectpicker.allowStandaloneObjects();
11688.5 In reply to 11688.4
Yes, I was selecting items within a group.
I will try your suggestions when I have a free moment.
Frederick
11688.6 In reply to 11688.4
Your first idea seems to have solved the problem.
While we are looking at this code one question:
When invoking the command the first thing it does is put up a dialog requiring me to pick STL or 3DM.
I always pick STL.
Is there any way to bypass the asking and simply default to STL?
Frederick
11688.7 In reply to 11688.6
Hi Frederick,
Yup, in ExportParts.js find line 22 that has this:
if ( WaitForDialogDone() ) DoExportParts(objectpicker.objects);
and change it to this:
/*if ( WaitForDialogDone() )*/ DoExportParts(objectpicker.objects);
That will bypass the asking stage and go immediately to the exporting.
Then to make it use .stl format find line 29 which has this:
var d = moi.ui.commandUI['extension'].value;
var d = '.stl'; /*moi.ui.commandUI['extension'].value;*/
That will make it always use STL format instead of getting it from the UI control.
11688.8 In reply to 11688.7
I can handle that.
I even understand most of it.
Frederick
Show messages: All  1  2-8
