Is this within the realm of "not too hard" for MoI
All  1-8  9-13
11687.9 In reply to 11687.8
Hi Frederick
If you don't need the threads, you can set the "Thread length" value to 0.
Here you can see this option both in ui and inside .htm file. (Line 97)
Also, "Angle" value controls the head and nut's fillet angle.
Size: 22 KB, Downloaded: 127 times, Dimensions: 396x437px
Size: 15.2 KB, Downloaded: 116 times, Dimensions: 1581x154px
11687.10 In reply to 11687.8
Hi Frederick,
> Can this kind of code be executed in a script file or must it be done in an .htm file?
It can go in either the .js file or the .htm file.
A long time ago (maybe V2 ?) there was a performance advantage to putting it in the .htm file which is why it's there. There isn't any difference anymore.
11687.11 In reply to 11687.9
It's an impressive bit of work but it appears to only make plain head bolts - no socket head, pan head, button head, flat head - all with a hex recess for the Allen tool - and that is what I desire.
Frederick
11687.12 In reply to 11687.11
Hi Frederick, you also might check out FreeCAD, it has a fasteners module:
https://wiki.freecad.org/Fasteners_Workbench
11687.13 In reply to 11687.12
I will check that out - I have heard of FreeCAD but a quick dive into a long while back made me really appreciate MoI.
I've got the "top-of-the-line" Alibre which has a ton of features - and I use Moi for most of my work.
Frederick
Show messages: All  1-8  9-13
