Import cloud points options?
All  1  2-12
11686.2 In reply to 11686.1
I’ve done it before with Notepads “find and replace”
I think i resorted to excel once also. More powerful options for tuples..
I didn't ask Michael about it though. Maybe he has a more eloquent way…
EDITED: 24 Mar 2025 by BURRMAN
A cool free prog about cloud points! ;)
http://cloudcompare.org
My Moi French Site
11686.4 In reply to 11686.1
Hi Matadem, here's a modified version of the ImportPointFile script which should handle your CAM program's point output.
This one should skip the G1 at the start of a line and will remove any X or Y label on the coordinates.
Instructions for installing a plugin here.
Hope this helps,
11686.5
Michael can it do z as well?
I tried the script and it works fast and efficient as always.
Tnx!
11686.6 In reply to 11686.5
Hi Matadem,
I didn't see any z coordinates in your example, but it if it has a 'Z' label on it like it does for X and Y you can update the script to handle that.
Open the ImportPointFilematadem.js file in a text editor and on line 112 which currently has this:
			if ( val[0].toUpperCase() == 'X' || val[0].toUpperCase() == 'Y' )
Change it to this instead:
			if ( val[0].toUpperCase() == 'X' || val[0].toUpperCase() == 'Y' || val[0].toUpperCase() == 'Z' )
11686.7
Works good!
Tnx!
11686.8 In reply to 11686.7
Sorry if I am interrupting this thread, but can this script import point clouds created via photogrammeyry. I use Zephyr3D for my photscans.
Ken
11686.9 In reply to 11686.8
Hi Ken,
The script can import points that are listed in .csv file.
It should be a text file with the x,y,z coordinates for one point on each line of the file.
11686.10
Good day.
One more issue.
The script is working awesome.
When I probe walls and unusual shapes it works...
but today I found out that if I probe circles it will run another type report. and then the script will not work.
the new report looks like this
Version: 0.0.0.1 1
New Probe Cycle
Enter Description Here
2025-Mar-23 00:13:52
Center of Bore
-5.557700
0.243719
3.664379
New Probe Cycle
2025-Mar-23 10:10:48
Center of Bore
-2.541250
-0.250592
1.620377
first is x the second y and the 3rd is radius.
Is there a way for the script to read the points and create the circles based on the radius info????
Tnx!
11686.11 In reply to 11686.10
Hi Matadem, here is a circle reading script.
11686.12
Thank you very much.
These will save me allot of time!!!!
Show messages: All  1  2-12
