Import cloud points options?
11686.1
Good day.
I have finally got my cnc probe working.
the issue I have now is that it outputs the file like this.
X1.7116 Y0.0000 Z0.0000
X1.7138 Y0.0203 Z0.0000
X1.7149 Y0.0406 Z0.0000
X1.7166 Y0.0610 Z0.0000
and If I am not mistaken Moi can import it only like this?
1.7116, 0.0000 ,0.0000
Anyone might know a quick way to change it from what Moi can read or that can Moi read it as is?
the main export is as the attached pic....so is there way for Moi to read it as is it will save me allot of time.
Thanks!
EDITED: 24 Mar 2025 by MATADEM
Size: 85.4 KB, Downloaded: 222 times, Dimensions: 399x631px
11686.2 In reply to 11686.1
I’ve done it before with Notepads “find and replace”
I think i resorted to excel once also. More powerful options for tuples..
I didn't ask Michael about it though. Maybe he has a more eloquent way…
EDITED: 24 Mar 2025 by BURRMAN
A cool free prog about cloud points! ;)
http://cloudcompare.org
My Moi French Site
11686.4 In reply to 11686.1
Hi Matadem, here's a modified version of the ImportPointFile script which should handle your CAM program's point output.
This one should skip the G1 at the start of a line and will remove any X or Y label on the coordinates.
Instructions for installing a plugin here.
Hope this helps,
11686.5
Michael can it do z as well?
I tried the script and it works fast and efficient as always.
Tnx!
11686.6 In reply to 11686.5
Hi Matadem,
I didn't see any z coordinates in your example, but it if it has a 'Z' label on it like it does for X and Y you can update the script to handle that.
Open the ImportPointFilematadem.js file in a text editor and on line 112 which currently has this:
			if ( val[0].toUpperCase() == 'X' || val[0].toUpperCase() == 'Y' )
Change it to this instead:
			if ( val[0].toUpperCase() == 'X' || val[0].toUpperCase() == 'Y' || val[0].toUpperCase() == 'Z' )
11686.7
Works good!
Tnx!
11686.8 In reply to 11686.7
Sorry if I am interrupting this thread, but can this script import point clouds created via photogrammeyry. I use Zephyr3D for my photscans.
Ken
11686.9 In reply to 11686.8
Hi Ken,
The script can import points that are listed in .csv file.
It should be a text file with the x,y,z coordinates for one point on each line of the file.
11686.10
Good day.
One more issue.
The script is working awesome.
When I probe walls and unusual shapes it works...
but today I found out that if I probe circles it will run another type report. and then the script will not work.
the new report looks like this
Version: 0.0.0.1 1
New Probe Cycle
Enter Description Here
2025-Mar-23 00:13:52
Center of Bore
-5.557700
0.243719
3.664379
New Probe Cycle
2025-Mar-23 10:10:48
Center of Bore
-2.541250
-0.250592
1.620377
first is x the second y and the 3rd is radius.
Is there a way for the script to read the points and create the circles based on the radius info????
Tnx!
11686.11 In reply to 11686.10
Hi Matadem, here is a circle reading script.
11686.12
Thank you very much.
These will save me allot of time!!!!
