Expanded Coordinate Window
All  1-3  4-5
11680.4 In reply to 11680.3
Hi Craig, from Finder click the "Go" menu on the top menu bar and choose "Go to Folder..." and put in:
~/Library/Application Support/Moi/startup
Then copy the attached ExpandCoords.js file into there.
After that when you start up MoI that script should run and make the space for xyz coordinates larger.
Hope that helps, - Michael
11680.5 In reply to 11680.4
Perfect! Thank you! This allows me to select the point creation tool and run around on surfaces, edges, etc to quickly check grade. I don't often need more than a couple decimal places but this leaves me plenty of room.
Size: 2.3 MB, Downloaded: 214 times, Dimensions: 3680x2382px
Show messages: All  1-3  4-5
