Scripts and AI intergration
All  1  2-10
11676.2 In reply to 11676.1
Hi Alex, I don't have any expertise in that area so I'm sorry I don't have any answer on that for you. It's not likely to be an area that I would be working on myself.
11676.3 In reply to 11676.1
Hi Alex,
For what it's worth, some time back I was playing with ChatGPT and asking it to suggest javascript methods to simulate bending solids in MoI. I was initially intrigued to see that it seemed to know something about the MoI API, but as the conversation iterated, I quickly observed that while it had ideas about algorithms and syntax, it really didn't know much about scripting in MoI. The particularly irritating aspect was its confidence in its answers--it did not take long for me to get fed up with correcting it & get generally irritated with its "oh yes, that makes sense" sort of replies to my corrections. I'm not particularly enthusiastic about AI...mildly intrigued maybe, but...
--Larry
It seems like AI can "cobble together" lots of information, but without intelligence, only pseudo-intelligence. Maybe AI would do better with NodeEditor?
11676.5
In a recent production exercise I required a large set of values based on tooling positions and their desired output I manually worked out a set 5 scenarios I then asked deepseek to take those figures and interpolate them across a large range of scenarios and it completed the task really efficiently I did a random check across some of the figures and they came in with in range the prompt was a simple request and completed in seconds - this type of integration I think for calculation gear ratios and various mechanical scenarios has huge potential and already has traction in various other cad packages - interesting to see it progress at stage a fast pace.
11676.6 In reply to 11676.5
Hi Alex,
I'm not sure that is enough to determine its correctness.
AI in engineering seems fraught with danger:
https://en.wikipedia.org/wiki/Hallucination_(artificial_intelligence)
11676.7
Language model are actually fascinating, having this next word prediction able to fool real conversation is crazy.
But in the other hand, that's all what it is, prediction, and guessing (hallucination). I wish sometimes I get a 'I don't know' reply instead of indeed having always something to say.
As for MoI usage, I guess your best bet is to give example code of "similar" script to help the model to write the syntax correctly during your request.
I manage to do a bit of openCL for Houdini with chatgpt that way. At some point I wasn't sure who was assisting who, but I usually have my stuff done. It's kinda helpful for "non coder" people to get a bit of work done and get more autonomy. That similar task would probably take my co worker 5min to solve tho.
11676.8 In reply to 11676.7
Does Ai can yet do that : give me in Language Vex ...anything you want ?
My Moi French Site
11676.9 In reply to 11676.8
Not really ... for a particular language like houdini vex, you need to have a good knowledge about the existing functions yourself, because it will simply assume it's C and extrapolate.
It does explains what he's trying to do tho, so with a bit of patience you end up with something 'working'.
So at the end you will have won some times or it's always a dream?
Show messages: All  1  2-10
