Delete objects by name, pattern matching, regex, etc
All  1  2-3
11674.2 In reply to 11674.1
Hi Frederick, there is selection by name with wildcard characters.
Type the Tab key which will put keyboard focus into the XYZ input in the bottom toolbar, then type your wildcard pattern and push enter.
The wildcard characters are * and ?
* matches any sequence and ? matches any single character.
So for example if have names like "nextbox" and "box8229" you can put *box* and that will select anything that contains "box" in it with anything before or after.
If you put box* that would only match box8229 and not nextbox.
That will select the objects, then use delete to remove them.
11674.3 In reply to 11674.2
That is fantastic.
Frederick
Show messages: All  1  2-3
