huge difference between file formats stp and MOI's 3dm
11661.1
Hello Michael and forum community,
I work with a lot of STP files, which I then clean up by deleting invisible objects and inner parts before saving them in MOI's native format.
Usually, the cleaned version saved as a 3DM file in MOI is about twice the size of the original STP.
However, some files turn out to be extraordinarily larger.
For example:
original file with a lot of inner parts and surfaces: 72mb in stp file format
moi clean version is 875mb in 3dm file format.
another example:
88mb in stp file format
527mb in 3dm file format
From my side, I only noticed that this issue occurs with files containing highly detailed geometry, like this part. Please take a look at the screenshot.
My question is very simple: why does this happen, and what can be done about it?
Thanks in advance
Size: 406.7 KB, Downloaded: 132 times, Dimensions: 1885x1420px
11661.2 In reply to 11661.1
Hi brr, it's kind of hard to diagnose without being able to analyze the actual files, but
it's likely that the ones with the biggest difference are using instancing in the STEP file.
Since MOI does not yet have an instancing mechanism, when it reads in the STEP file
any instances will become a full separate object.
There isn't really anything to do about it currently.
11661.3 In reply to 11661.2
Hello Michael,
Thank you for the information. Are there any plans to implement instancing in MOI v5?
Thanks in advance.
11661.4 In reply to 11661.3
Hi brr, sorry no not likely in the v5 timeframe.
What is instancing ?
My Moi French Site
11661.6 In reply to 11661.5
Hi Pilou, instancing is a method of managing a large number of copies of the same object.
11661.7 In reply to 11661.6
OK before an hypothetic instancing ...we can't simulate that ?
with copy to point by you
& VClone by MaxSMirnov
Vclone replaces the vector with the object with size and orientation!
11661.8 In reply to 11661.7
Hi Pilou, yes you can simulate some aspects but the main thing that the simulation is missing is efficency in data size.
With instancing each "instance" is handled by maintaining the insertion point and not making a full separate object copy.
11661.9 In reply to 11661.8
ok!
My Moi French Site
