Solid imports with errors
All  1-7  8-14
11653.8 In reply to 11653.1
Hi Bob,
Looks like getting your model out of Alibre is creating fairly bad geometry. Alot of little slivers and bad surfaces.
Here I cleaned a bunch of stuff to verify the model works, but due to my lack of patience to work on it for 3 or 4 hours to keep your original intent, I heavily altered a few areas to speed it up. (I deleted some internal surfaces that were Mangled and cut out entire sections to facilitate fixing 400 Naked edges, etc.) So here is your model which can now work as steps and sats, but it isnt your original intent.
If you had the patience, you can fix it up in MoI
But, since You believe you have a qualified solid in Alibe, maybe go over and ask those folks about your export issue. Maybe there is some type of tolerance setting that has it be "Light" in alibre, but doesnt allow the surface join to translate out. Or try separating everything in Alibre and exporting all separate surfaces and see if it can be joined into a solid outside..
Just spit balling. I don't have Alibre
11653.9 In reply to 11653.6
Hi Bob, could you post an SAT out from Alibre? Maybe that will be a better way.
The step file is a mess in Rhino8 as well.
11653.11
Here's a SAT zip. The Gods are against me, even the Zip files not wanting to convert properly!
EDITED: 26 Apr by APTIVABOY
11653.12 In reply to 11653.11
Hi Bob, are there any options for Alibre's SAT export? If so can you show me the options dialog for it?
Is the piece with fins one solid in Alibre or a bunch of separate surfaces? It seems to be surfaces in the SAT file.
11653.13 In reply to 11653.11
Is that SAT file from Alibre or MoI?
Its made with the harmony ware translator. I wasn't aware that Alibre used that library...
Since Alibre is Acis based, the best export out should be the SAT format, from Alibre.....
11653.14 In reply to 11653.11
Hi Bob, here's a version with things tuned up to be solids:
https://moi3d.com/temp/Bob9595593/Nacelle%20For%20Testing2_3dm.zip
There were several areas that had some teeny tiny micro edges, those can get in the way of joining. So I needed to reconstruct some places around those.
Show messages: All  1-7  8-14
