Spiral design for 3D print
All  1-3  4-6
11652.4 In reply to 11652.1
Hi Gunter, Brian's script here seems pretty close:
https://moi3d.com/forum/index.php?webtag=MOI&msg=6951.30
EDITED: 13 Feb 2025 by MICHAEL GIBSON
11652.5 In reply to 11652.1
Hi Gunter,
> Once, that spiral is sorted, how would I go about creating the variable depth of the relief?
So one possibility for the variable depth of the relief could come from doing a sweep
with profile curves that have a peak and dropoff shape to them.
Something like this, the profiles point upwards in Z and it would be good to make a profile station
for every spiral turn that get smaller so that the sweep won't bunch up on top of itself:
Then select the profile curves, and run Construct > Sweep and pick the spiral as the rail to generate this:
Draw in some lines and trim the spiral so you can form this planar region:
Select those curves and run Construct > Planar to fill that area in:
These can now be joined:
Looks like this:
11652.6 In reply to 11652.5
Michael, this is so helpful, thank you SO much!
Show messages: All  1-3  4-6
