Spiral design for 3D print
11652.1
Hi All,
I'd like to create a 3 dimensional plate with a spiral design similar to this:
I started off using a flat spiral curve but notice that the original is tighter in the centre and gradually widens out. Is there a way to adjust the flat spiral curve?
Once, that spiral is sorted, how would I go about creating the variable depth of the relief?
Many thanks in advance!
Gunter
Just use the "Edit Frame" ?
11652.3 In reply to 11652.1
Hi Gunter, there are a variety of different spiral scripts here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=7356.2
I think several of those will do variable distance instead of fixed distance like the regular command has.
11652.4 In reply to 11652.1
Hi Gunter, Brian's script here seems pretty close:
https://moi3d.com/forum/index.php?webtag=MOI&msg=6951.30
EDITED: 13 Feb 2025 by MICHAEL GIBSON
11652.5 In reply to 11652.1
Hi Gunter,
So one possibility for the variable depth of the relief could come from doing a sweep
with profile curves that have a peak and dropoff shape to them.
Something like this, the profiles point upwards in Z and it would be good to make a profile station
for every spiral turn that get smaller so that the sweep won't bunch up on top of itself:
Then select the profile curves, and run Construct > Sweep and pick the spiral as the rail to generate this:
Draw in some lines and trim the spiral so you can form this planar region:
Select those curves and run Construct > Planar to fill that area in:
These can now be joined:
Looks like this:
11652.6 In reply to 11652.5
Michael, this is so helpful, thank you SO much!
