Odd result with filleting
All  1-5  6-9
11651.6 In reply to 11651.5
Hi Gunter, when you're in a command the command options are shown in the upper right area of the main window.
When you're in the Fillet command (for MoI version 5) the Library option is here:
11651.7 In reply to 11651.6
Great, thank you Michael, sorted!
Gunter
11651.8
Hi Gunter
The problem was caused by your outer shape profile has a kink in it , they must be perpendicular (the inner vertical point is sitting inside the next 2 )
The 3 points that make it up on the vertical axis have to be on a straight line then the fillet will work
ps it will be easier to mirror and work on parts if you work around the origin
I have uploaded redraw
cheers
shayne
11651.9 In reply to 11651.8
Hey Shayne,
Thank you so much for figuring this out for me!
Many thanks!
Gunter
Show messages: All  1-5  6-9
