Odd result with filleting
All  1-3  4-9
11651.4 In reply to 11651.3
Hi Gunter,
> Just tried that and you're right it works but would still like to get to the bottom of the problem!
It looks like a bug in the conversion to ACIS geometry, I've added it to my list to investigate.
> Also, now I'm trying to fillet the inside of the ring and the same problem is happening:
It looks like you can get the inside ones done for now by switching the "Library" option inside the Fillet command options to "Library: Solids++".
11651.5 In reply to 11651.4
Thank you Michael,
Would you mind telling me how to do this - "switching the "Library" option inside the Fillet command options to "Library: Solids++".
Many thanks,
Gunter
11651.6 In reply to 11651.5
Hi Gunter, when you're in a command the command options are shown in the upper right area of the main window.
When you're in the Fillet command (for MoI version 5) the Library option is here:
11651.7 In reply to 11651.6
Great, thank you Michael, sorted!
Gunter
11651.8
Hi Gunter
The problem was caused by your outer shape profile has a kink in it , they must be perpendicular (the inner vertical point is sitting inside the next 2 )
The 3 points that make it up on the vertical axis have to be on a straight line then the fillet will work
ps it will be easier to mirror and work on parts if you work around the origin
I have uploaded redraw
cheers
shayne
11651.9 In reply to 11651.8
Hey Shayne,
Thank you so much for figuring this out for me!
Many thanks!
Gunter
Show messages: All  1-3  4-9
