Blue Flask alternative to access MoI_v5_API_...
Just installed the new Feb 8 beta. Very nice. The Alert boxes (e.g. for elastica and logspiral help ?), are much more readable.
So rather than modifying ui > SidePane.htm again, Modification by addition was made to ui > HelpMenu.htm, the flyout portion of the MoI Help ? button at the bottom right corner.
This avoids using up a valuable space in the sidepane edit menu, next to History.
This experimentation was done on the old Beta, to avoid messing up the new Beta.
Re-using Burr's shellExecute code, the modified HelpMenu.htm is as follows:
<html>
	<body class="MenuBody">
		<moi:FlyoutHeader />
		<moi:MenuItem onclick="moi.ui.createDialog( 'About.htm' );"><moi:Text textid="About menu item"/></moi:MenuItem>
		<moi:MenuItem onclick="moi.filesystem.shellExecute( moi.filesystem.getAppDataDir() + 'MoI_API\\MoI_v5_API_Documentation.htm' );"><moi:Text textid="About menu item"/></moi:MenuItem>
	</body>
</html>
I was unable to locate the moi:Text textid="About menu item", so the second "About MoI" line, in the flyout menu, is the link to the MoI_v5_API_Documentation htm.
And so was unable to show "About MoI-v5_API..." as a selection.
EDITED: 9 Feb 2025 by BEMFARMER
11647.2 In reply to 11647.1
re;
The <moi:Text textid="id"> element is for translatable text. It will look up that text id in the current language's string table.
The string tables are *Strings.txt files located in the ui subfolder.
So for this one you can find it in EnglishStrings.txt:
About menu item=About MoI
11647.3 In reply to 11647.2
Thank you Michael.
None of these API Documentation access changes are needed for normal CAD use of MoI.
It might be beneficial to script programmers.
At work, I added another line to ui > EnglishStrings.txt, line 224 +/-:
API menu item=API v5b Documentation
Also, in the modified ui > HelpMenu.htm, change the second "About menu item" to "API menu item"
In the Help flyout menu, a second text line will now appear with this menu item title.
For translations, another one line addition could also be done to the corresponding language string. e.g. FrenchStrings.txt, SpanishStrings.txt, etc., (I think),
at about line 225.
(My very poor suggestion: API menu item=Au Sujet de API)
(Or maybe add in the word "Documentation" in French???)
(Or something else?...)
EDITED: 10 Feb 2025 by BEMFARMER
