V5 beta Feb-8-2025 available now
 1-16  17-36  37-56  57-76
11646.17
Hi Miachael.
I think there's a bug when entering the distance and angle with the new Polyline feature, as it only seems to work as expected in Top view. If using the feature in Front and Right view, then the result is correct, but is always applied to the X,Y plane.
Cheers, Martin.
11646.18 In reply to 11646.17
Hi Martin,
It's actually not a bug, that's to be consistent with existing 2D coordinate entry.
Like if you are drawing a line and type in a 2D coordinate like 5,5 that is taken as an x,y value. It doesn't change depending on the view.
Same thing with existing polar coordinate entry, you can enter 5<45 for example which will be taken as an x,y value.
So the new "relative to previous line segment direction" polar coordinate entry does that also.
Maybe these should be view dependent but it probably wouldn't be good for just one of them to do that.
11646.19 In reply to 11646.18
Hi Miichael.
Thanks for explaining the reason for the behaviour in the other views - I hadn't thought of that. ;-)
As this function doesn't require any X,Y or Z reference from the user and only needs a relative distance & angle input, then as someone who might well forget about it only applying in Top view, I think I'd be in favour, if possible, to allow it to function in the other views as an option - if you think that's possible without compromising anything else.
Thanks for all the improvements you've been busy making in MoI - I'm looking forward to the release of V5.
Martin.
EDITED: 4 Mar 2025 by BLOWLAMP
11646.20 In reply to 11646.19
Thanks Martin, yes I can set up an option for making 2D coordinate entry being view dependent.
But putting that aside for the moment, does it seem like this new left/right coordinate entry is ok ?
11646.21 In reply to 11646.20
Thank you for adding that Michael. I'll find that very helpful.
"But putting that aside for the moment, does it seem like this new left/right coordinate entry is ok ?"
What I found it a little awkward at first, was keeping track of where left and right were switching to, as I added other sections to the polyline at various angles, but it soon started to become second nature.
Once that became familiar, I tried things like entering 20r120 instead of 20R60 and 20r225 instead of 20L45 which all seemed to work as well, if that's what you want to do.
I finally succeeded in getting MoI to generate a script error by pushing my luck and entering 20r180-45 to see if it might calculate the angle. ;-)
So the short answer Michael, is that it all works very well.
Thanks again.
Martin.
11646.22
Hi Michael.
Is there a way to use more than one Division snap when a construction line is in use?
I needed 12 evenly spaced circles of various sizes along a line and it would have been ideal to have the snap points remain onscreen until all 12 had been drawn.
I wondered if there is a modifier key option or script that would keep construction lines active and the selected tool 'live', instead of clearing after a single use?
Thanks. Martin.
11646.23 In reply to 11646.22
Hi Martin,
Yes, check out here:
http://kyticka.webzdarma.cz/3d/moi/#KeepCLine
You must draw the helper lines then call the script !!!
So when you change your function draw the Helper lines then recall the script
so you will have all the helper Lines of all functions ! :)
You have also this one by Paul (in English! ;)
slightly different : run the script - draw some helpers Lines (in the script itself) - click in empty space -
call a function Draw (with also its own helper if wanted ...these will be not saved) etc..
http://moi3d.com/forum/index.php?webtag=MOI&msg=1029.1k
All lines are kept, erase last one, erase all are also possible!
You can also rename and color like a layer technic (but color will be not visible but effective if hide "red" selection!) any moment ! (so hide some named selections)
( change color is not shown here)
EDITED: 6 Mar 2025 by PILOU
11646.25 In reply to 11646.1
Some thoughts on V5
- cursor change on more of the long running operations - like grouping
- an easier way to activate the grouping operation on selected items - when far down in the list of objects and a few have been selected, scrolling all the way to the top is not much fun
- perhaps ask for the group name at time of creation
- so far I have no found a way to move more than one item at a time into an existing group
That is all for now - I will continue to test
Frederick
11646.26 In reply to 11646.25
Hi Frederick, thanks for testing it!
for this one:
You can go to Options > Shortcut keys , push "Add" and set the Key to something like Ctrl+G and for the "Command" part put in Group.
The grouping mechanics are modeled after the behavior of groups in 2D vector drawing programs. The typical behavior (like in Affinity Designer, MS Office, Inkscape) is to automatically name the group and not ask for the name at creation time.
You can do it by selection - select the multiple objects you want to move and right click on the name of the existing group (or left click on the existing group and choose "Assign selection here").
The "Move" menu item lets you move an object to a group without needing to set up object selection first.
11646.27 In reply to 11646.25
Hi Frederick, for setting the name of the group at creation time, I've attached an alternate group command that will do that.
Instructions for installing a plug-in here.
You would set up a shortcut key with GroupSetName as the command name to run this one instead of the regular Group command.
11646.28 In reply to 11646.26
Thanks for the reply.
Creating the shortcut key works just fine.
And adding multiple objects to a group via selection works just fine too.
As to not asking for the name of the group when creating it - since I never used any of those other programs I was not aware of the "normal" behavior.
Just the same your program is so unique and incredibly good perhaps you can lead the way to a "better" approach.
Frederick
11646.29 In reply to 11646.27
You are just an amazing person.
The things you can make MoI do are incredible and very welcome.
Frederick
11646.30 In reply to 11646.1
I have found that when working on projects, when it comes to import/export I am mostly:
- importing from my "models" folder - where I keep the models that are used in the projects
- exporting to my "exports" folder the STLs that are used for printing
So it would be handy to have a way of specifying default folders for import and export - possibly with the option to specify different export folders for different types of things being exported (STL, 3DM, etc.)
Just an idea.
Frederick
11646.31
Hi Micheal,
Unsure if this has been bugged before but getting a decent amount lot of selection issues as attached - surfaces highlight on other objects (but don't actualyy 'select' as it were), occasionally materials will also jump to random surfaces as the selection does (but don't actually change materials in the browser, just appear to on screen)
Seems that if I've had a step file import at some stage in the model it occurs more often?
// Rich
EDITED: 28 Apr 2025 by -RB-
Size: 188.9 KB, Downloaded: 175 times, Dimensions: 2326x1505px
11646.32 In reply to 11646.31
Hi Rich,
I've never seen this and I frequently import STEP files.
It would help if you upload a .3dm where this problem is occurring.
- Peer
11646.33 In reply to 11646.31
Hi Rich, yes can you please post a .3dm file where you're seeing this?
I did get one similar bug report for materials jumping around and it turned out to be a buggy video driver.
What operating system are you running on?
Message 11646.34 deleted 1 May 2025 by -RB-
11646.35
Ah I'm getting errors uploading and NDA anyway but good to know it might be a video issue, yes just interesting it always seems to pop up with the import of a step...Hopefully just disappears with next beta. If I cut/paste the moi native effected geo in again it clears the problem up if that's any lead
11646.36 In reply to 11646.35
Hi Rich, the error on upload will happen if the file is too large, like more than 10Mb.
For large files you'll need to use a file sharing service like WeTransfer, Dropbox, OneDrive, etc... where you upload the file there and share a link to it. You can e-mail the link to me at moi@moi3d.com if you want to keep it private.
If you're on Windows it would probably be a good idea to update your video driver to the latest version from the video card vendor's web site.
Show messages:  1-16  17-36  37-56  57-76
