Select edges based on proximity
All  1-9  10-16
11643.10 In reply to 11643.4
Thanks for tips about rj-graffix pressure (PEER).
Just discovered a new thing in illustrator the other day( maybe it´s been there for years).
When holding down the delete key you can drag selections that gets deleted right away, and it works with both regular selection tool aswell as lasso tool.
I´ve been selecting stuff and pressing delete for every single object or line for over 20 years :-)
11643.11 In reply to 11643.10
Hi Juniper,
Thanks for the tip about holding down the delete key. I didn't know that.
- Peer
11643.12 In reply to 11643.9
Hi Juniper, a couple of other things that may be useful:
If you make a mistake in selecting, unselecting, or hiding something you can use undo to revert it. Only the most recent action is held in undo for this so do the undo for this before doing any other selection.
Another thing is if you have a pretty complex set of edges you want to hide instead of only hiding them you can assign them a name so you can hide or show them again as a set using the Scene Browser.
So for example here's a script you can set on a shortcut key that will hide the current selection but also set the object names to "Hide edges" so you can manipulate them in the scene browser:
script: /* Hide and assign to name "Hide edges" */ var objs = moi.geometryDatabase.getSelectedObjects(); if ( objs.length > 0 ) { objs.setProperty( 'name', 'Hide edges' ); moi.geometryDatabase.hide(); }
Another thing is if you want to show just one or some of the currently hidden edges instead of all of them, you can do a Ctrl+click on the Edit > Hide button in the side pane to do a "Show subset". That will temporarily show all hidden objects and let you select one or more of them and then when you finish just those selected ones will remain shown.
11643.13 In reply to 11643.12
Hi Michael, and thanks, I didn´t know about the "Show subset", it makes it a bit easier to see whats hidden.
Sometimes i just hide the edges or put them in a style and then hide the style.
"Show subset" feels lika a faster and easier way to work, thank you!
11643.14
Is there any way I could just select the edges thats visible by dragging in the window and not the edges not visible(backside or see through).
11643.15 In reply to 11643.14
Hi Juniper,
Sorry no there isn't a way to do that with window select.
11643.16 In reply to 11643.15
No worries, thanks for answering
Show messages: All  1-9  10-16
