Flatten curves
All  1-4  5-10
11642.5 In reply to 11642.4
Hi Matadem, with that method watch out for gaps between pieces. Pepakura designer is more meant to handle low polygon output where you are going to fold paper along poly edges.
But it looks like it's handling your case as a larger developable surface ok.
11642.6 In reply to 11642.4
As Michael mentioned Rhino is great for very accurately unwrapping surfaces. I've designed complex tube notched structures, unrolled the tubes, and used a cricket cutter to create full size templates. Everything fit perfectly in the real world and welded up nicely. It's amazing to have the ability to create a complete set of templates and jigs in moi3d that translates into a perfect fit in steel.
Size: 221.9 KB, Downloaded: 184 times, Dimensions: 1280x960px
Size: 314.2 KB, Downloaded: 164 times, Dimensions: 1280x960px
Size: 199.1 KB, Downloaded: 167 times, Dimensions: 1280x960px
Size: 332.6 KB, Downloaded: 171 times, Dimensions: 1280x960px
11642.7
Yep hopefully Moi will get this feature in the future.
Because I use Moi for everything lol....from paper to metal, from concept to reality :D
You have FormZ Free for Unfold! ;) (FormZ to Moi in step
Minute 24.10 That was Version 9, totay it's V 10 ;)
EDITED: 7 Mar 2025 by PILOU
11642.9 In reply to 11642.6
Hi Craig,
Thanks for sharing your template technique. That is pretty cool!
- Peer
11642.10 In reply to 11642.9
Your welcome! I had a blast figuring it out and was happy to find that it worked well. Looking forward to using it on a larger scale project.
Show messages: All  1-4  5-10
