Flatten curves
All  1  2-10
11642.2 In reply to 11642.1
Michael's UnwrapCurve script will to the "flattening". Can use it as shortcut key.
11642.3 In reply to 11642.1
Hi Matadem, MoI does not have a general developable surface unwrapper. Check out Rhino for that.
But for the case of a cylinder you can try doing it in MoI using using curve to curve flow.
You will need to create a line that is the same length as the circle circumference. You can do this either by getting the length of the circle using Details... > Curve properties > "Length" and then create a line of that length or also the UnwrapCurve plugin mentioned by Brian above can do it. UnwrapCurve is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5136.1
Place the line at the bottom point of the circle like this:
Now select the curve you want to flatten. And run Transform > Deform > Flow. When the prompt says "Select base curve or surface", select the circle as the base curve. The next prompt will say "select target curve near matching end". Click on the line.
11642.4
I do not have Rhino.
But I did find a quick solution
Export as 3d stl from Moi to Pepakura designer - unfold, export as dwg/svg back to Moi edit as needed then send to cut.
Tnx!
Size: 52.7 KB, Downloaded: 200 times, Dimensions: 1038x619px
11642.5 In reply to 11642.4
Hi Matadem, with that method watch out for gaps between pieces. Pepakura designer is more meant to handle low polygon output where you are going to fold paper along poly edges.
But it looks like it's handling your case as a larger developable surface ok.
11642.6 In reply to 11642.4
As Michael mentioned Rhino is great for very accurately unwrapping surfaces. I've designed complex tube notched structures, unrolled the tubes, and used a cricket cutter to create full size templates. Everything fit perfectly in the real world and welded up nicely. It's amazing to have the ability to create a complete set of templates and jigs in moi3d that translates into a perfect fit in steel.
Size: 221.9 KB, Downloaded: 184 times, Dimensions: 1280x960px
Size: 314.2 KB, Downloaded: 164 times, Dimensions: 1280x960px
Size: 199.1 KB, Downloaded: 167 times, Dimensions: 1280x960px
Size: 332.6 KB, Downloaded: 171 times, Dimensions: 1280x960px
11642.7
Yep hopefully Moi will get this feature in the future.
Because I use Moi for everything lol....from paper to metal, from concept to reality :D
You have FormZ Free for Unfold! ;) (FormZ to Moi in step
Minute 24.10 That was Version 9, totay it's V 10 ;)
EDITED: 7 Mar 2025 by PILOU
11642.9 In reply to 11642.6
Hi Craig,
Thanks for sharing your template technique. That is pretty cool!
- Peer
11642.10 In reply to 11642.9
Your welcome! I had a blast figuring it out and was happy to find that it worked well. Looking forward to using it on a larger scale project.
Show messages: All  1  2-10
