Auto dimensions
All  1-18  19
11637.19 In reply to 11637.18
As always, thank you for the detailed explanation.
>>Why are you concerned about it? - I thought it was an issue since out of 48 models, only 3 had this problem. I also made the mistake of thinking that the BoundingBox command that I use in the app is the same as the one in the scripting doc. I was confused because if I selected the model in the scene and ran BoundingBox, I got good results (a bounding box perfectly encasing my model with the right values), but through the script, I got different values. Adding "true" to the command inside the script fixed that. So all good. (full disclaimer, I have almost no experience scripting but with what you provided, chatGPT was able to make a fully working script)
I will send you the models per mail.
>>Some things that I would check if I had the file to examine - are the objects solids? - yes
Are there any additional construction curves still hanging around? - no
What is the "Canvas megapixel resolution" value set to? - 50
Try increasing that value to 50 or 60 if it's lower than that. - same result at 10, 50 and 100
Show messages: All  1-18  19
