COOL ! Blender Import/Export add-on
All  1  2-18
11634.2 In reply to 11634.1
Hi KenMo,
> Love the Blender Import / Export add-on (or is it plug-in, script or ?).
I don't know, do you have a link?
> Thanks Micheal for this wonderful plugin/add-on/ script. It opens up an
> whole new world for me.
It isn't mine.
> ** why are there three options to import an OBJ? what is the difference between the three,
I would need to take a look at it to try and answer this and I need a link to it to do that.
> I thought MOI3D could not deal with models created in polygonal apps and is a reason why Sketchup models can not bee imported?
It can work ok in limited circumstances with low polygon counts, but will tend to become unworkable with more polygons.
CAD models are not designed to be made up of hundreds of thousands of little flat facets.
11634.3 In reply to 11634.2
Here is the link in the MOI forum where Frenchy Pilou posted the link. Looks like it was from github. I recalled installing it but had forgotten all about it. Works great.
Check the MOI <> Blender thread at your MOI Forum for info. Sorry but when I post a link to the thread it does not open the thread, only the Discussions room.
SO I posted a reply in the original MOI <> Blender thread to make it current.
https://moi3d.com/forum/index.php?webtag=MOI
So is it a script, add-on, pug-in? And what is the difference between the three (if any) ?
Also shown are the two other options to bring an OBJ into MOI3D "subdiv",and "impObj". I find the BMOI add-on superior to the other two options. Never get any satisfactory results with either.
EDITED: 18 Jan 2025 by KENMO
11634.4 In reply to 11634.3
Hi Ken,
> So is it a script, add-on, plug-in?
Those are all more or less the same thing. You could call it any one of those.
11634.5 In reply to 11634.3
Hi KENMO,
I'm interested in this. Could you please point to the right link?
(because your current link brought us to the forum index instead)
Thank you very much in advance.
11634.6 In reply to 11634.5
@Elang, I think this is it:
https://github.com/TitusLVR/BMOI_Connector
11634.7 In reply to 11634.6
Thank you very much, Michael.
Edit:
I can't get both import and export to work:
- the export throws 'Error writing file'
- the import shows (an instantly closed) UI which says : "Joining. Press ESC to skip"
I'm using the still running V5 beta
EDITED: 23 Jan 2025 by ELANG
11634.8 In reply to 11634.7
Hi Elang,
It says:
quote:
System requirements:
Windows 10
Windows 10 temp folder location must be by default
What is your temp folder location? If you press Win+R and put in %temp% what location opens?
11634.9 In reply to 11634.8
Hi, Michael...
it's : C:\User\%username%\AppData\Local\Temp
I'm using windows 11, by the way.
Thank you for the fast respond.
11634.10 In reply to 11634.9
Hi Elang, your Temp folder looks fine.
If you create a folder named BMOI inside %temp% does it then work ok?
It appears that you need to run the blender plugin once first before you use the MOI side so that sub-folder inside the temp folder will get created.
Here's a version that should work on Mac.
The install is mostly the same as on the main page:
You put the MOI scripts under ~/Library/Application Support/Moi/commands and ~/Library/Application Support/Moi/startup
and the Blender script goes under ~/Library/Application Support/Blender/<BlenderVersion#>/scripts/addons/BMOI_Connector/__init__.py
EDIT: updated Mac version to put temp files directly in /tmp instead of in subdirectory since some on some OS versions there are permission issues with writing to the subdirectory.
EDITED: 30 Jan 2025 by MICHAEL GIBSON
11634.12 In reply to 11634.11
Thanks Michael.
www.jameselliott.co.uk
11634.13 In reply to 11634.5
Sorry in the delay in replying but it appears Mr Gibson posted the link.
Ken
11634.14 In reply to 11634.11
For Blender it's OK but for MoI on my MacBook M2 pro it's not.
There are 3 files in each folder?
03 - 05 after I open MoI.
Marek
Size: 105.1 KB, Downloaded: 216 times, Dimensions: 1540x468px
Size: 96.8 KB, Downloaded: 199 times, Dimensions: 1530x398px
Size: 53.9 KB, Downloaded: 153 times, Dimensions: 716x458px
Size: 95.7 KB, Downloaded: 158 times, Dimensions: 1436x622px
Size: 144.1 KB, Downloaded: 146 times, Dimensions: 2150x1282px
11634.15 In reply to 11634.14
Hi Marek, there are 3 files to put in the commands folder and 1 file to put in the startup folder.
When the .zip file is unzipped, there will be 3 files inside MOI3D/Commands - "bmoi_export_FBX.js", "bmoi_Import_OBJ.htm", "bmoi_Import_OBJ.js".
These 3 go into ~/Library/Application Support/Moi/commands like you show. These should not go into ~/Library/Application Support/Moi/startup so remove them from there.
The 4th file to copy is "97 BMoi.js" in the .zip file under MOI3D/startup - this is the one to put in ~/Library/Application Support/Moi/startup , this is what makes the buttons show up in the bottom toolbar.
When you do the export from MOI you need to select the objects that you want to transfer. If you don't then the "Nothing is selected" error will show.
11634.16 In reply to 11634.15
Sure enough, now all is fine after following your answer.
Thanks a lot.
Marek
11634.17 In reply to 11634.15
Updated Mac version attached above:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11634.11
Updated Mac version to put temp files directly in /tmp instead of in subdirectory since some on some OS versions there are permission issues with writing to the subdirectory.
11634.18 In reply to 11634.17
Love this plugin. It is a must have.
Show messages: All  1  2-18
