COOL ! Blender Import/Export add-on
All  1-13  14-18
11634.14 In reply to 11634.11
For Blender it's OK but for MoI on my MacBook M2 pro it's not.
There are 3 files in each folder?
03 - 05 after I open MoI.
Marek
Size: 105.1 KB, Downloaded: 216 times, Dimensions: 1540x468px
Size: 96.8 KB, Downloaded: 199 times, Dimensions: 1530x398px
Size: 53.9 KB, Downloaded: 153 times, Dimensions: 716x458px
Size: 95.7 KB, Downloaded: 158 times, Dimensions: 1436x622px
Size: 144.1 KB, Downloaded: 146 times, Dimensions: 2150x1282px
11634.15 In reply to 11634.14
Hi Marek, there are 3 files to put in the commands folder and 1 file to put in the startup folder.
When the .zip file is unzipped, there will be 3 files inside MOI3D/Commands - "bmoi_export_FBX.js", "bmoi_Import_OBJ.htm", "bmoi_Import_OBJ.js".
These 3 go into ~/Library/Application Support/Moi/commands like you show. These should not go into ~/Library/Application Support/Moi/startup so remove them from there.
The 4th file to copy is "97 BMoi.js" in the .zip file under MOI3D/startup - this is the one to put in ~/Library/Application Support/Moi/startup , this is what makes the buttons show up in the bottom toolbar.
When you do the export from MOI you need to select the objects that you want to transfer. If you don't then the "Nothing is selected" error will show.
11634.16 In reply to 11634.15
Sure enough, now all is fine after following your answer.
Thanks a lot.
Marek
11634.17 In reply to 11634.15
Updated Mac version attached above:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11634.11
Updated Mac version to put temp files directly in /tmp instead of in subdirectory since some on some OS versions there are permission issues with writing to the subdirectory.
11634.18 In reply to 11634.17
Love this plugin. It is a must have.
Show messages: All  1-13  14-18
