Finding Tangents to a Curve
 1-5  6-25  26-45  46-61
11632.6 In reply to 11632.3
I added a third GetTangents line with (1,0,0)
With the (2d) LogSpiral script run, in either Top, Front, or Right view, the modified GetTangents script finds the Horizontal and Vertical tangent points.
(A curiosity, the LogSpiral just needs to be created by the LogSpiral script. The LogSpiral script does not have to be completely closed (Done +Done), but can be finished (Done + Done).)
11632.7 In reply to 11632.6
The GetTangents script works on many tested 2d curves.
Curves like the helix did not have any such tangents.
Curves with line segments???
The script does not like sphere, cone, cylinder, box.
The script does not like blank screen. (No geometry)
EDITED: 20 Jan 2025 by BEMFARMER
11632.8 In reply to 11632.5
> So maybe add some "pick curve" dialog, and somehow place the curve at the top of the "curve list".???
Yes that wasn't really meant to be a finished tool, it was just some example script code for calling crv.getTangentsToDir() so you could use it in your own script you're working on.
Here's an adjusted version that will work on selected curves:
function GetTangents( crv, dir )
    var params = crv.getTangentsToDir( dir );
    for ( var i = 0; i < params.length; ++i )
	var pt = crv.evaluatePoint( params.item(i) );
	var factory = moi.command.createFactory( 'point' );
	factory.setInput( 0, pt );
	factory.commit();
var curves = moi.geometryDatabase.getSelectedObjects().getCurves();
for ( var i = 0; i < curves.length; ++i )
	var crv = curves.item(i);
	GetTangents( crv, moi.vectorMath.createPoint(1,0,0) );
	GetTangents( crv, moi.vectorMath.createPoint(0,1,0) );
	GetTangents( crv, moi.vectorMath.createPoint(0,0,1) );
Yes a helix is a 3D curve it doesn't have any spots on it that are tangent to the world x/y/z axis directions. The tangent of a helix will have some component of the helix axis direction in it.
11632.9 In reply to 11632.4
Forgive a mini-hijack of the thread please, but Michael's code fragment prompts a related question.
I am seeking to write a script to simulate bending metal barstock based on the method described in the attached file. The first step of the method is to find the red lines tangent to two curves, but I'm not thinking that getTangentsToDir() is going to help me find such. Am I wrong, or are there any other tangent methods that might help? I reviewed the V4 and V5 beta notes but didn't find anything promising.
--Larry
11632.10 In reply to 11632.8
Thank you again for this terrific script.
I've assigned it a hotkey.
It may be included in a future program.
11632.11 In reply to 11632.9
Hi Larry, there is curve.getTangentsToDir( dir ) and curve.getTangentsToPoint( pt ) but neither of them will calculate tangents between 2 curves.
Are your 2 curves always circles or circular arcs like in your .3dm file?
11632.12 In reply to 11632.9
Hi Larry
I vaguely recollect this Tangent lines to two circles from a few years ago.
https://en.wikipedia.org/wiki/Homothetic_center
https://en.wikipedia.org/wiki/Tangent_lines_to_circles
Still researching...
There is a MoI tan/tan tan/tan snap, if the start and end points are in the vicinity (by eye) of the tan points..
EDITED: 17 Jan 2025 by BEMFARMER
So calculate the inner homothetic point, (x0,y0), and then use curve.getTangentsToPoint( pt ) (???)
Sounds relatively do-able.
11632.14 In reply to 11632.13
Some partial code, untested:
// z plays the roll of y in xz plane.
// or use circle1 and circle 2, and extract circle1.x circle1.z, etc.
function GetInnerHomotheticPt( radius1, x1, z1, radius2, x2, z2 )
var y0 = 0.0;
var radiusSum = radius1 + radius2;
var ratio1 = radius1/radiusSum;
var ratio2 = radius2/radiusSum;
var x0 = ratio2 * x1 + ratio1 * x2;
var z0 = ratio2 * z1 + ratio1 * z2;
return moi.vectorMath.createPoint( x0, y0, z0 );
// select left circle (roller) and die circle, and get centerPt1 and radius1 and centerPt2 and radius2... and centerPt1.x1, centerPt1.z1, etc.
// or pass centerPt1 and centerPt2 and extract .x1 etc in function called.
// Also need to do same thing for right hand circle (roller), as there will be TWO InnerHomothetic points.
var ptInner1 = GetInnerHomotheticPt( radius1, x1, z1, radius2, x2, z2 );
factory.setInput( 0, ptInner1 );
factory.commit();
// Repeat for ptInner2.
// Now use ptInner1 with curve.getTangentsToPoint( ptInner1 )to find
// tangent point of left circle (roller), and also for die (semi)circle.
// Repeat with ptInner2 for right circle, and also for die (semi)circle.
- B
11632.15 In reply to 11632.11
Yes, the circular arcs will be the most common sort of die to simulate.
Thank you for your references & code, I shall read and tinker further!
--Larry
11632.16 In reply to 11632.15
Hi Larry,
The case of tangent between 2 circles can be solved directly.
A really good source for this kind of thing is the book "A Programmer's Geometry", which can be accessed on archive.org here:
https://archive.org/details/AProgrammersGeometry
See section 2.6 "Tangents between 2 circles".
I spent some time working on tangents to two disjoint circles, and reviewing lots of forum posts, and several existing scripts.
Larry's code here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9916.22
provides short and simple code to select the "Roller" circle, arc Die circular arc, and the second "Roller" circle, in all views.
The center points are created. var cpoint = curves.item( i).conicFrame.origin;
I am wondering if cpoint.x, and cpoint.y, and curves.item(i).radius will yield the (x,y,0) coordinates, and the radius of each circle???
(In MoI5 beta???)
Or is some GetRadius, or evaluate... needed?
Or is var x = cp.distancex( cpoint).toFixed( digits);
var y = cp.distancey( cpoint).toFixed( digits);
var z = cp.distancez( cpoint).toFixed( digits);
needed??? (MoI4???)
And can the .toFixed(digits) be omitted???
It seems like cpoint is a "raw" point, not a Geometry point???
pointfactory can turn cpoint into a Geometry point.
EDITED: 18 Jan 2025 by BEMFARMER
11632.18 In reply to 11632.16
Too much Fortran for me:-)
I think r + ve means radius with a positive value. (ve meaning value???)
On second thought, I think that r + ve, means use the positive version of radius. (ve meaning version)
Looking at the ax + by +c = 0 equation,
a = (-/+ radiusL +/- radiusK) * (xL - xK) - ...
where xL means the x coordinate of the center point L of circle L.
rL means the radius of circle L.
The inner and outer tangent line equations are calculated using the 4 combinations of +/- radiusL and +/- radiusK
So the math is not as abstruse as I initially thought.
How to convert ax + by + c = 0 into a MoI line segment???
AI conclusions may or may not be faulty, but:
AI Overview
Learn more
To plot a line from the equation "ax + by + c = 0," you need to first rearrange the equation to solve for y (to get it in slope-intercept form, "y = mx + b"), then find the y-intercept (b) and the slope (m), and use those values to plot the line on a graph by finding two points on the line and connecting them; you can also find the x and y intercepts directly by plugging in 0 for y and x respectively and solving for the other variable.
11632.19 In reply to 11632.17
> (In MoI5 beta???)
cpoint.x and cpoint.y will have the x,y coordinates of the circle's center point, and curves.item(i).conicRadius will have the radius value.
.toFixed() is for converting a numeric value into a string value.
11632.20 In reply to 11632.19
Thank you very much Michael.
I reviewed the 1983 geometry book, and adjusted previous post :-)
11632.21 In reply to 11632.18
See page 10 "Conversion from Implicit to Parametric Form".
When you have it in parametric form you can get 2 points on the line by evaluating the parametric form at t = 0 and t = 1.
Slope intercept form is usually avoided because it has difficulty with vertical lines.
I think the ve is "vector expression".
Anyway the thing that's really good about this book is that usually you don't have to translate from math notation into code, it also gives code.
So in this case "Finding a tangent may be coded:" at the bottom of page 34.
11632.22 In reply to 11632.21
Actually I think the "ve" comes from some math notation when illustrating +/- values.
"+ve" is shorthand for "positive". (label shown on the + branch of a +/- value)
"-ve" is shorthand for "negative". (label shown on the - branch of a +/- value)
In this book I don't think you'll see any "ve" in the code section, just as an abbreviation for "positive" and "negative" on illustrations.
11632.23 In reply to 11632.22
I'll agree with you on the Pos/Neg concept. (Never seen this notation before, and ve is not defined in the text, AFAIK.) I'll have to study the 1983 book more...
The book does mention optical quality resolution being "poor" (1983) (Readability). The book states that lower case and upper case identify the same "parameters", for readability.
Putting ve after the + or - makes the symbols stand out...
Attached is a script to calculate the Homothetic point for two circular arcs or circles, in the XZ plane, Front view. It does not work in other views.
y and z get mixed up.
I was unable to get cplane to make it work on other views. It is confusing. I dabbled with cplane, without success.
Time for me to move on, as this is Larry's project :-)
I guess the Homothetic point could be used with the MoI5 beta method mentioned earlier by yourself, to draw inner half tangent lines...
It does not matter in which order the two "circles" are selected.
EDITED: 19 Jan 2025 by BEMFARMER
11632.24 In reply to 11632.23
11632.25
Hi All,
I have also been playing with tangents to get the CNC Pipe bender working I have found that is some instances where freestyle organic curve needs to be converted I do a manual divide of the curve in roughly equal segments which I then manually drag constant tangents which gives me a pretty good result but I have found in some instances that tube bending software does not like these conversions. If import the curve into solidworks there is an option to lock endpoints to tangent when I do this the curves work and if I overlay the curves MOI vs SOLIDWORKS there are slight differences. I have included a sample file with both sets overlayed and the scroll file converted the manual way with endpoint locked to tangent. Someway of MOI being able two adjust to curves against each into a tangent position would be great.
Show messages:  1-5  6-25  26-45  46-61
