Finding Tangents to a Curve
 1-15  16-35  36-55  56-61
11632.36 In reply to 11632.35
Thank you Michael
Today I learned about Browsing the Wiki and Resources pages, and about searching, and Search.
- B
11632.37 In reply to 11632.35
Brian made corrections to post 11632.34. MoI v5 API does have those two methods documented.
PEER had made the additions some months ago.
I do not know how or where they learned of the new methods.
I had an old copy on both computers.
For closed curves, the GetTangents script( crv, dir ) will place an extra tangent point at the end of the curve (if it exists there).
I guess I can add code for if crv.isClosed, reduce params.length by 1, and not do the extra horizontal or vertical tangent point (if it exists there), for the end of the curve.(?)
To be tried later...
I need to learn about how this curve parameter thing works...Are there any recommended (NURBS?) references or forum information??
EDITED: 21 Jan 2025 by BEMFARMER
11632.38 In reply to 11632.37
NURBS references:
https://preserve.mactech.com/articles/develop/issue_25/schneider.html
https://en.wikipedia.org/wiki/Non-uniform_rational_B-spline
https://www.rhino3d.com/features/nurbs/
A curve parameter is a numeric value that defines a location along the curve, ranging from the start of the curve being crv.domainMin to the end of the curve being crv.domainMax.
You can generate a cartesian x,y,z point value at a curve parameter by using crv.evaluatePoint( t ), or other information at that position with crv.evaluateTangent( t ), crv.evaluateCurvature( t ) or crv.evaluateDerivatives( t ).
11632.39 In reply to 11632.38
The parameter business in the API was always a puzzle for me too, but with Michael's pointer to A Programmer's Geometry I'm starting to get a better sense of what's going on. Still have a mental gap between the equations given and MoI though. Relative to parameters, taking the diagram on pg 11, (x0, y0) is somewhere on the line (wherever the normal intersects) and seems from the code to be where t=0 (via algebra), however that does not then sync with parameter values ranging from 0 to 1 to describe the complete line. Makes me wonder if the t parameters are interpreted differently in different forms of equations? My computed tangents do not look correct and are winding up in screwy locations, so I'm still going over my code.
The other puzzlement is how to update the equations and code for the implicit form (section 2) to include the 3rd dimension. Book seems to give hints later on when it gets into lines and planes in space (section 7).
Paging back & forth in the PDF inspired me to order a used copy yesterday. Gotta love bookfinder.com to find good prices on used books, in this case about $7 delivered. Even though I'm in way over my head, I very much appreciate these pearls of wisdom Michael, thank you! Schneider in particular looks to be very worthwhile to better appreciate how these things work...
--Larry
11632.40 In reply to 11632.39
The 4 tangent points can be ("easily") calculated with trigonometry equations, as detailed at stack exchange forum.
These equations may be the ones used in Barry's node???
-Brian
I will post the link later.
Re: 3d geometry:
If one View is stuck to, say Front view, xz plane, y is zero, and z plays the role of Y in equations.
A cplane could be set, with two circle centers, with z = 0, calculations done, and then the tan points translated back to World coordinates. (poorly understood by myself).
If the rollers are restricted to xy or xz, or yz, the circle or arc curves could use a couple of isPlaner and another method to differentiate between, I think (???)
( I find the cPlane conversions puzzling / confusing)
11632.41 In reply to 11632.40
With the leg up from your initial code, I had the generalized 3D version working to produce the tangent points in short order. My brain revolted when I tried to understand the node though. Will look forward to your link.
When trying to work with the 2D equations from the book, my thought was to also try for the generalized 3D solution as well. I think the coordinateFrame from the two circles provides the key information about which view is involved, and that code based upon this information would then work naturally with a cPlane as well. Given how much self awareness the MoI objects have, to my mind it is tantalizing to be able to feed that context into these equations to get new MoI objects without my clumsy attempts to explicitly map a particular view. (if that makes sense)
For what it's worth, here's my 3D modification to your initial code example:
function GetInnerHomotheticPt( circle1, circle2 )
    if (( circle1.isArc || circle1.isCircle ) &&
        ( circle2.isArc || circle2.isCircle )) {
        var centerPt1 = circle1.conicFrame.origin;
        var centerPt2 = circle2.conicFrame.origin;
        var radiusSum = circle1.conicRadius + circle2.conicRadius;
        var ratio1 = circle1.conicRadius / radiusSum;
        var ratio2 = circle2.conicRadius / radiusSum;
        var x0 = ratio2 * centerPt1.x + ratio1 * centerPt2.x;
        var y0 = ratio2 * centerPt1.y + ratio1 * centerPt2.y;
        var z0 = ratio2 * centerPt1.z + ratio1 * centerPt2.z;
        var pt = moi.vectorMath.createPoint( x0, y0, z0 );
        return pt;
function GetTangents( crv, pt )
    var params = crv.getTangentsToPoint( pt );
    for ( var i = 0; i < params.length; ++i )
	var pt = crv.evaluatePoint( params.item( i ) );
	var factory = moi.command.createFactory( 'point' );
	factory.setInput( 0, pt );
	factory.commit();
// then in the calling function
    var ptInner1 = GetInnerHomotheticPt( botDie1, topDie );
    GetTangents( botDie1, ptInner1 );
    GetTangents( topDie, ptInner1 );
    var ptInner2 = GetInnerHomotheticPt( botDie2, topDie );
    GetTangents( botDie2, ptInner2 );
    GetTangents( topDie, ptInner2 );
--Larry
11632.42 In reply to 11632.41
Calculating tangent points with Trig. link:
https://math.stackexchange.com/questions/719758/inner-tangent-between-two-circles-formula
Hi Larry,
Congrats on your new script!
I see that you used the new beta v5 crv.getTangentsToPoint( pt ) method.
I need study and try out your script.
I did not know that the ratios worked in 3d.
11632.43 In reply to 11632.41
??? An extra point might be created with a (closed) circle, if the tangent happens to occur where the curve start point equals the curve end point. (Seam in extruded circle) ???
11632.44 In reply to 11632.43
A line factory can be used to create the line segment tangents, from pairs of points.
- b
11632.45 In reply to 11632.42
Thanks for the link! One of the cool things about the book's code is that it also seeks to be computationally efficient...avoiding the expensive operations like the trig functions. Not that this really matters in this context, just shows that I'm old & have an appreciation of why fast code is worthwhile.
Here's the current effort but only because you mentioned trying it. Nowhere near complete...
--Larry
EDITED: 21 Jan 2025 by FAHNOE
11632.46 In reply to 11632.45
Terrific script.
For the top die, the tangent points of interest lie "below" its centerpoint. (?)
A short arc can be built between these two points.
For the bottom dies, the tangent points of interest lie "below" their centerline. (?)
If the "seams" (join point) of the circles are placed in the proper positions, and the circles are in the proper orientation [ CounterClockwise left die with Clockwise upper die ], or [ CW right die with CCW upper die ], then the first tangent point encountered for each circle will be the desired one, pairwise. The seams should be closest to the centerline midpoint. Which is the lowest point on the upper die circle, and innermost point of the outer two dies. ( This might be the midpoint of the upper die? )
Does MoI have any ways to determine CW vs CCW for the circles?, or arcs?
image host
11632.47 In reply to 11632.46
If you get 3 distinct points on the arc (on a circle don't get start/mid/end because start and end are the same), you can then calculate the signed area of the 2D triangle which will be negative for clockwise order, positive for counter-clockwise.
Script code for calculating this is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=11521.42
11632.48 In reply to 11632.47
Thank you Michael.
So if Larry decides to use CW vs CCW, the dies only need to be set up once, which can be done before tangent scripts are used...
The parametric order of crv.getTangentsToPoint( pt ) would be from circle start to circle end, around the circle. Or from arc startPt to arc endPt, around the arc.(?)
CW FLIPS to CCW (?)
11632.49 In reply to 11632.48
Once again, you guys are way out ahead & I'm the lucky beneficiary, thank you both.
--Larry
11632.50 In reply to 11632.49
Hi Larry,
try this Bend Tool nod file you can adjust roller centres, radii etc.
Hope this helps it is based on https://www.youtube.com/watch?v=BTi0KM5vYPQ
Barry
New version see http://moi3d.com/forum/index.php?webtag=MOI&msg=11632.58
EDITED: 23 Jan 2025 by BARRY-H
11632.51 In reply to 11632.48
When you call crv.getTangentsToPoint( pt ), it will return a list of numbers. Each number is a curve parameter value marking the location on the curve of a tangent solution.
Curve parameters will be inside the parametric domain of the curve, between crv.domainMin at the start of the curve, ranging up to crv.domainMax at the end of the curve.
11632.52 In reply to 11632.51
Thank you Michael.
If a programmer wanted to utilize the new list of numbers in order, from start to end,
is the list already in order, corresponding to: from curve start to curve end?
Or is it necessary to do any ".sort BySelectionOrder()," which is sometimes done when selecting geometry in other code ?
So the code line:
transforms (evaluates) each params number to locate/create a new RAW point on the curve, ( with coordinates in the current cplane ).
A line drawn from such a (tan) point, to the initial External point, will be tangent to the starting curve, at said new point location on the curve.
Sorry to be wordy, but it helps me to understand :-)
I just ordered a used copy of the programmers book also.
On the API I also see the curve methods:
equallySpacedPoints? (No documentation in API)
getArcLengthParam Would this method enable a programmer to find the parameter where the ArcLength of the curve is some specific value? And evaluate the point there?
11632.53 In reply to 11632.52
Yes the returned list of parameters is sorted in ascending order.
> So the code line:
The resulting point will be in world coordinates, not necessarily in the current cplane.
If you want coordinates relative to the current cplane you would need to transform it.
Yup, like this:
11632.54 In reply to 11632.52
crv.equallySpacedPoints( NumSegments ); - takes one argument for number of segments, returns a list of NumSegments+1 parameter values to produce segments of equal arc lengths.
crv.getArcLengthParam( NormalizedDistance ); - takes one argument of either a number or sorted array of numbers with normalized distance values between 0 and 1 and returns curve parameter values for position at that arc length along the curve.
So for example crv.getArcLengthParam( 0.5 ) will return the parameter value at half the distance along the curve.
11632.55 In reply to 11632.54
Hi Michael.
Your documentation is excellent. IMHO
Maybe PEER will update the MoI v5 API?
-Brian
Show messages:  1-15  16-35  36-55  56-61
