Finding Tangents to a Curve
 1-10  11-30  31-50  51-61
11632.11 In reply to 11632.9
Hi Larry, there is curve.getTangentsToDir( dir ) and curve.getTangentsToPoint( pt ) but neither of them will calculate tangents between 2 curves.
Are your 2 curves always circles or circular arcs like in your .3dm file?
11632.12 In reply to 11632.9
Hi Larry
I vaguely recollect this Tangent lines to two circles from a few years ago.
https://en.wikipedia.org/wiki/Homothetic_center
https://en.wikipedia.org/wiki/Tangent_lines_to_circles
Still researching...
There is a MoI tan/tan tan/tan snap, if the start and end points are in the vicinity (by eye) of the tan points..
EDITED: 17 Jan 2025 by BEMFARMER
So calculate the inner homothetic point, (x0,y0), and then use curve.getTangentsToPoint( pt ) (???)
Sounds relatively do-able.
11632.14 In reply to 11632.13
Some partial code, untested:
// z plays the roll of y in xz plane.
// or use circle1 and circle 2, and extract circle1.x circle1.z, etc.
function GetInnerHomotheticPt( radius1, x1, z1, radius2, x2, z2 )
var y0 = 0.0;
var radiusSum = radius1 + radius2;
var ratio1 = radius1/radiusSum;
var ratio2 = radius2/radiusSum;
var x0 = ratio2 * x1 + ratio1 * x2;
var z0 = ratio2 * z1 + ratio1 * z2;
return moi.vectorMath.createPoint( x0, y0, z0 );
// select left circle (roller) and die circle, and get centerPt1 and radius1 and centerPt2 and radius2... and centerPt1.x1, centerPt1.z1, etc.
// or pass centerPt1 and centerPt2 and extract .x1 etc in function called.
// Also need to do same thing for right hand circle (roller), as there will be TWO InnerHomothetic points.
var ptInner1 = GetInnerHomotheticPt( radius1, x1, z1, radius2, x2, z2 );
var factory = moi.command.createFactory( 'point' );
factory.setInput( 0, ptInner1 );
factory.commit();
// Repeat for ptInner2.
// Now use ptInner1 with curve.getTangentsToPoint( ptInner1 )to find
// tangent point of left circle (roller), and also for die (semi)circle.
// Repeat with ptInner2 for right circle, and also for die (semi)circle.
- B
11632.15 In reply to 11632.11
Yes, the circular arcs will be the most common sort of die to simulate.
Thank you for your references & code, I shall read and tinker further!
--Larry
11632.16 In reply to 11632.15
Hi Larry,
The case of tangent between 2 circles can be solved directly.
A really good source for this kind of thing is the book "A Programmer's Geometry", which can be accessed on archive.org here:
https://archive.org/details/AProgrammersGeometry
See section 2.6 "Tangents between 2 circles".
I spent some time working on tangents to two disjoint circles, and reviewing lots of forum posts, and several existing scripts.
Larry's code here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9916.22
provides short and simple code to select the "Roller" circle, arc Die circular arc, and the second "Roller" circle, in all views.
The center points are created. var cpoint = curves.item( i).conicFrame.origin;
I am wondering if cpoint.x, and cpoint.y, and curves.item(i).radius will yield the (x,y,0) coordinates, and the radius of each circle???
(In MoI5 beta???)
Or is some GetRadius, or evaluate... needed?
Or is var x = cp.distancex( cpoint).toFixed( digits);
var y = cp.distancey( cpoint).toFixed( digits);
var z = cp.distancez( cpoint).toFixed( digits);
needed??? (MoI4???)
And can the .toFixed(digits) be omitted???
It seems like cpoint is a "raw" point, not a Geometry point???
pointfactory can turn cpoint into a Geometry point.
EDITED: 18 Jan 2025 by BEMFARMER
11632.18 In reply to 11632.16
Too much Fortran for me:-)
I think r + ve means radius with a positive value. (ve meaning value???)
On second thought, I think that r + ve, means use the positive version of radius. (ve meaning version)
Looking at the ax + by +c = 0 equation,
a = (-/+ radiusL +/- radiusK) * (xL - xK) - ...
where xL means the x coordinate of the center point L of circle L.
rL means the radius of circle L.
The inner and outer tangent line equations are calculated using the 4 combinations of +/- radiusL and +/- radiusK
So the math is not as abstruse as I initially thought.
How to convert ax + by + c = 0 into a MoI line segment???
AI conclusions may or may not be faulty, but:
AI Overview
Learn more
To plot a line from the equation "ax + by + c = 0," you need to first rearrange the equation to solve for y (to get it in slope-intercept form, "y = mx + b"), then find the y-intercept (b) and the slope (m), and use those values to plot the line on a graph by finding two points on the line and connecting them; you can also find the x and y intercepts directly by plugging in 0 for y and x respectively and solving for the other variable.
11632.19 In reply to 11632.17
> (In MoI5 beta???)
cpoint.x and cpoint.y will have the x,y coordinates of the circle's center point, and curves.item(i).conicRadius will have the radius value.
.toFixed() is for converting a numeric value into a string value.
11632.20 In reply to 11632.19
Thank you very much Michael.
I reviewed the 1983 geometry book, and adjusted previous post :-)
11632.21 In reply to 11632.18
See page 10 "Conversion from Implicit to Parametric Form".
When you have it in parametric form you can get 2 points on the line by evaluating the parametric form at t = 0 and t = 1.
Slope intercept form is usually avoided because it has difficulty with vertical lines.
I think the ve is "vector expression".
Anyway the thing that's really good about this book is that usually you don't have to translate from math notation into code, it also gives code.
So in this case "Finding a tangent may be coded:" at the bottom of page 34.
11632.22 In reply to 11632.21
Actually I think the "ve" comes from some math notation when illustrating +/- values.
"+ve" is shorthand for "positive". (label shown on the + branch of a +/- value)
"-ve" is shorthand for "negative". (label shown on the - branch of a +/- value)
In this book I don't think you'll see any "ve" in the code section, just as an abbreviation for "positive" and "negative" on illustrations.
11632.23 In reply to 11632.22
I'll agree with you on the Pos/Neg concept. (Never seen this notation before, and ve is not defined in the text, AFAIK.) I'll have to study the 1983 book more...
The book does mention optical quality resolution being "poor" (1983) (Readability). The book states that lower case and upper case identify the same "parameters", for readability.
Putting ve after the + or - makes the symbols stand out...
Attached is a script to calculate the Homothetic point for two circular arcs or circles, in the XZ plane, Front view. It does not work in other views.
y and z get mixed up.
I was unable to get cplane to make it work on other views. It is confusing. I dabbled with cplane, without success.
Time for me to move on, as this is Larry's project :-)
I guess the Homothetic point could be used with the MoI5 beta method mentioned earlier by yourself, to draw inner half tangent lines...
It does not matter in which order the two "circles" are selected.
EDITED: 19 Jan 2025 by BEMFARMER
11632.24 In reply to 11632.23
11632.25
Hi All,
I have also been playing with tangents to get the CNC Pipe bender working I have found that is some instances where freestyle organic curve needs to be converted I do a manual divide of the curve in roughly equal segments which I then manually drag constant tangents which gives me a pretty good result but I have found in some instances that tube bending software does not like these conversions. If import the curve into solidworks there is an option to lock endpoints to tangent when I do this the curves work and if I overlay the curves MOI vs SOLIDWORKS there are slight differences. I have included a sample file with both sets overlayed and the scroll file converted the manual way with endpoint locked to tangent. Someway of MOI being able two adjust to curves against each into a tangent position would be great.
11632.26 In reply to 11632.9
Hi Larry,
not sure if this is what you are trying to achieve but I did this trial with the nodeditor.
Your drawing does not show the top circle in the middle of the 2 bottom circles ?
My method starts with the bend angle required and works out the movement required but
the top circle is in the middle so may not be what you require.
Anyway if its of any use let me know and I will finish it.
Barry
11632.27
You guys are way faster than me! ;-} I'm following along and slowly digesting.
I'd gotten started with Brian's ideas & then got diverted with the book Michael referenced. After studying the book & muddling about with the conversions between the forms of equations, I thought that Brian's suggestion on finding the homothetic centers and using getTangentsToPoint() were much easier to work with. At this point I have the rudiments working, but not really something worth posting yet. This conversation has been very helpful, thank you!
Barry, I'd thought of the NodeEditor, but have never done anything with it. Whether your node solves my puzzle or not, I would certainly encourage you to finish it as I'm sure there will be many who may appreciate that. I'm impressed at how quickly you got to the essence of what I was describing earlier! In this case my desire was to be able to play with the sizes and positions of the die elements to achieve the effect I was after. Maybe that is doable in the NodeEditor, but for my pea-brain, doing it with a script was easier to conceive.
Alex, you're closer to the realm I'm thinking of (real world bending of metal), but much more advanced given use of a CNC bender. Your work is just remarkable! I work on a smaller scale & while I have both Hossfeld and DiAcro manual benders, I had an idea for a die to do a compound bend similar to an S-hook in a single operation. So I designed the die in MoI and then built it. The first iteration of the design didn't do quite what I wanted, but after a revision and remaking some of the parts I'm pretty close to what I want. This exercise got me to thinking that a simplified bending script would speed up the design process, hence my noodling. For reference, here is an illustration the die in use; designed to bend a bunch of carpentry nails for use in a sculpture.
--Larry
11632.28 In reply to 11632.27
Hi Larry,
attached nod file for you to try.
Have added a material thickness or diameter and the bend is based on the centre line.
Barry
Updated to work with nodeditor plus.(only)
EDITED: 19 Jan 2025 by BARRY-H
11632.29 In reply to 11632.28
Hi Barry,
Remarkable! But when I opened the macro, oh my! Have never used visual programming tools, so this is totally new, but your example is much appreciated.
Here I go, sticking my foot in something I clearly do not understand... It seems like the centerline ought to be tangent to the top roller's larger radius, like you've done on the bottom roller. Or maybe you're just taunting me to figure it out and fix it myself... I suspect that when you added the thickness/diameter, you updated the bottom rollers but not the top. c'mon Larry, spot the difference!
--Larry
11632.30 In reply to 11632.29
Hi Larry,
does the attached photo help or are your results different.
The bottom rollers are one side of material and the top the other.
Barry
Show messages:  1-10  11-30  31-50  51-61
