Extrude from a point
All  1-5  6-9
11627.6 In reply to 11627.5
Hi Wisty,
Is the attached what you want? I got this result by drawing helper lines in blue, copying your profile curve so that the first corner matched up with the first blue line, and then scaling the profile to get the second corner to match the second helper. Finally, I selected both profiles and did Construct > Loft.
- Peer
11627.7 In reply to 11627.5
I'm thinking that the profile should be appropriately scaled, and placed at the big end target??? And re-extrude to point?
Maybe a cPlane, or at lease direction set?
- B
11627.8 In reply to 11627.6
Thank you Peer , I will use that technique again. It was the fact that extrude was so close that was throwing me.
11627.9
Why not create the small end profile and scale it to the size of the large end? Then you could extrude this profile to a point.
I made some videos of me making a bevel gear in MoI a long while ago, Maybe they will help.
https://vimeo.com/1047669344
https://vimeo.com/1047670578
Cheers, Martin.
Show messages: All  1-5  6-9
