Interpolate curve on surface?
Is there a command to interpolate a curve on a surface?
(Rhino has this command)
In the case of an extruded surface:
Recreate a 3d scroll curve, (now lost) from its 2d projection in the xy plane, (Top View).
Given 11 known points (x,y) on the 2d curve, and their corresponding known 11 points (x,y,z) on the desired 3d scroll curve. (Violin scroll 3d curve)
The desired 3d curve is on the extruded (in z direction) surface of the 2d curve.
In other words, interpolate xyz points, but keep all xy values on the extruded surface.
I think it could be done with 11 unwraps of the 2d curve, to locate the 11 2d points on the unwrapped (unrolled) curve. Then add the z values to locate the 11 3d points on the flat (unrolled) 3d curve. Then interpolate the 11 new 3d points to create flat (unrolled) 3d curve. Then Flow
Said curve to create desired 3d scroll curve, using flattened (unrolled) 2d curve as base, and curved 2d scroll curve as target curve. ???
(The curves are, more or less, multiple semi-circular curves.)
EDITED: 11 Jan 2025 by BEMFARMER
How about doing interpcurve on the 11 3d points, then project the new curve on to the extruded surface?
11619.3 In reply to 11619.1
Hi Brian, there is not a command in MOI for interpolating a curve on a surface.
But as you mention you can get a curve on surface using Construct > Curve > Project or Construct > Curve > Isect. Or Flow.
If you're still stuck can you please post a file with the points and surface?
Thanks, - Michael
11619.4 In reply to 11619.3
Thank you Michael.
I am still entering geometry into MoI.
