3D Criss Cross shape
All
1-7
8-10
gunter511
9 Jan 2025 (8 of 10)
11618.8
In reply to
11618.7
Hi again Barry,
Thank you so much for your explanation and the attached file too!
Am I correct that to point the ends downwards, you did "Show pts", selected the ones and the tip and then dragged them down in the z axis?
Many thanks!
Gunter
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
BurrMan
9 Jan 2025 (9 of 10)
11618.9
In reply to
11618.5
“””””” Also, I'd like the pointed ends to bend downward slightly (in the z axis). Could you explain how I can do this please?””””
Use Flow
Before you bollean and fillet the parts together, do a curve-curve flow.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Barry-H
9 Jan 2025 (10 of 10)
11618.10
In reply to
11618.8
Hi Gunter,
Yes I just moved curve points.
Barry
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-7
8-10
