drawing arc tangent to 2 curves through a specific tangent point
All  1-13  14-15
11616.14 In reply to 11616.13
Re:
> Basically the circle tangent solver doesn't like to be given coincident
> points. Internally it's trying to generate a circle through 3 points
> which is undefined when the 3 points are collinear or coincident.
Thanks for explaining. I wasn't thinking of this command as a circle through 3 points. Was instead thinking of it as picking 2 curves and then picking a point that the tangent arc must go through. I thought the first 2 points were used to select the single closest solution if there are multiple solutions. But now I see that I'm never picking any particular curves.
Re:
> I'm not understanding this part.
Here are 2 cases where the pointpicker is in a region where there's no solution, but the closest solution is drawn.
- Peer
11616.15 In reply to 11616.14
Hi Peer,
Well it is doing that (either 2 curves + point or 3 curves) but for each curve the point on the curve is part of what it is gathering.
The point on each curve will be used as the starting parameter for the solver, it will converge to the closest solution to those starting points.
Show messages: All  1-13  14-15
