NodeEditor Plus [Unofficial]
 1-18  …  59-78  79-98  99-118  119-120
11614.99 In reply to 11614.98
Ah damned vicious bug syntax...i must be all re-read! :)
EDITED: 27 Dec 2025 by PILOU
Ok not yet finishing but that is working : Curious as a simple bad ...'... can erase 3 errors messages at different places on the code '
Toolotips are missing....
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.zip
11614.101 In reply to 11614.100
As in the MoI interface, where I don't use the same terms as you, I'll have to review the translation of the node editor and go down to line 2975.
But I don't think that will console you!
Come on, cheer up.
Salut,
Comme dans l'interface de MoI, où je n'utilise pas les mêmes termes que toi, je vais devoir revoir la traduction de l'éditeur de nodes et aller jusqu'à la ligne 2975.
Je ne pense pas que cela va te consoler!?
Allez, courage.
Zooen toujours avec deux "o" monsieur Pilu.
11614.102 In reply to 11614.101
Yep I must finish the first draw!
It's yet a miracle that all is working! :)
11614.103 In reply to 11614.102
Tutorials please :D
11614.104 In reply to 11614.103
For you the English version is yet ready! :)
https://moi3d.com/forum/messages.php?webtag=MOI&msg=11614.1
and after some tutorials https://moiscript.weebly.com/biblio-elephant.html French / English
EDITED: 30 Dec 2025 by PILOU
Last version of the Lang.js (French) till line 2985.... and it's working! :)
@MO_TE
Does the tooltips are yet ready in the English Version and how to see them on the screen of NodEditorPlus?
something to enable ?
Because seems to see them in orange previously!
Another thing : does i must Copy Past lines 2983 - 4157 and put FR
then Translate
or just change EN to FR line 2983 ?
then translate ?
EDITED: 1 Jan by PILOU
11614.107 In reply to 11614.106
Thank you for your contribution to the French translation.
Node tooltips are accessible via holding Alt and left-clicking on the node.
>> do i must Copy Past lines 2983 - 4157 and put FR
>> then Translate
You can leave them as they are; They are not for translation. thank you.
11614.108 In reply to 11614.107
THx for the Infos!
My Moi French Site
Yep but i can make that! ;)
Ps Seems thats working also fine with the French version !
You right all is yet fine i don't know why! :) (French Tooltips also) D:)
For a little test... transform a cube to a pyramid ... as the direct generation of the file don't yet works
Here the manual method not sure that really help! :)
1. Create the Base Shape ... Add a Curve/Rectangle node.
Set Width to 20 and Height to 20.
This represents the footprint of your shape on the ground.
2. Elevate the Top Profile... Add a Transform/Move node.
Connect the Rectangle output to the Objects input of the Move node.
In the Translation field, set the Z value to 30 (format: 0,0,30). This defines the height.
3. Control the Taper (The "Magic" Step) ...Add a Transform/Scale node.
Connect the Move output to the Objects input of the Scale node.
Crucial: Set the Center of the Scale node to 0,0,30 (the same height as your moved square).
Add a Basic/Slider node. Set its range from 0.0 to 1.0.
Connect the Slider output to the Factor input of the Scale node.
Slider at 1.0 = Cube
Slider at 0.0 = Pyramid
4. Group the Profiles... Add a Logic/BundleArray node.
Connect the original Rectangle (from Step 1) to In 1.
Connect the Scale output (from Step 3) to In 2.
This creates a list containing both the bottom and top squares.
5. Generate the Volume...Add a Construct/Loft node.
Connect the BundleArray output to the Profiles input.
MoI3D will now stretch a "skin" between the two squares.
6. Final Output... Add a Basic/Output node.
Connect the Loft output to it to see the final geometry in the MoI3D viewport. ...
Quick Tip: If you want the pyramid to be "solid" (a closed BREP),
make sure to check the "Cap ends" option if it's available in your version of the Loft node, or use a Solid/PlanarSrf on the result.
Curious result ... but surely schematic
a node Object / Selected don't exist anymore ?
Waiting more something like that! :)
But not yet tested because it's while i don't touch this sort of thing!
But terrific if you can ask an Ia to make for you anything you want without knowledge of Nodes!
Maybe not today at 100% but surely after tomorrow!
EDITED: 2 Jan by PILOU
11614.113
Generating an object in NodeEditor is quite similar to how it's done in moi, but with parametric capabilities.
Here are two simple methods to generate a pyramid.
This node has been relocated to the "Select" menu, under the title "Select Scene Objects". It's also accessible in the search box.
Size: 24.9 KB, Downloaded: 40 times, Dimensions: 501x237px
Size: 192.2 KB, Downloaded: 41 times, Dimensions: 1094x600px
Size: 32.3 KB, Downloaded: 36 times, Dimensions: 271x375px
11614.114 In reply to 11614.113
Excellent! Where is the Search Box ? (how to call it ?
Center ?
11614.115 In reply to 11614.114
Double-click on the canvas (NodeEditor window) :)
11614.116 In reply to 11614.115
That is wortking!
11614.117
Great Work MO!
// Rich
11614.118 In reply to 11614.1
Hi Mo,
been playing with your unwrap curve / surface node.
Have you an example as getting shapes that need scaling so not sure I am using it correctly.
Barry
Show messages:  1-18  …  39-58  59-78  79-98  99-118  119-120
