NodeEditor Plus [Unofficial]
 1-10  11-30  31-50  51-70  71-90  …  111-120
11614.31 In reply to 11614.30
Bonjour Phiro
Thank you for your contributions... which make this software magical and a forum rich with great people.
Merci pour vos contributions ... qui rendent ce logiciel magique et un forum riche de belles personnes.
chri
EDITED: 26 Dec 2024 by CHRI
Is beautiful that please without concept! My Moi French Site "http://moiscript.weebly.com
Note that old node programs, (assemblages of old nodes), may open and work in NodeEditorPlus, but they may look different, and inherit some differences from the new node.
Example: ConvertPts from an old node program. Mode order is different, but it still functions. Opening the new, Plus version shows different input and output.
I did an update of ConvertPts2, (it had some harmless errors as well, and was not multitype), to do interpcurve curves rather that control point curves, and called it ConvertPts3. It would go in the extension folder. (not uploaded) . Interpcurve could be added to ConvertPts, in the points.js big file.
EDITED: 28 Dec 2024 by BEMFARMER
11614.34 In reply to 11614.33
Here is a modified points.js file, as points.zip, which adds interpcurve to ConvertPts, as InterpCurve U, and InterpCurve V. (For NodeEditorPlus)
If desirable, this would replace points.js in NEPlus.
I'll leave it up to MO, whether to adopt this modification or not, and will delete this file for room, in a few days, either way.
I had to be extremely careful to spell the new words correctly. Failure for spellings to agree yields strange results, orange lights, etc.
Curve V and InterpCurve V just made a bunch of points in a pile in my test script.
I think that to re-used old node program assemblages, all nodes in them should be replaced with NEPlus version, even if they "look right".
Re-save the upgraded node program. Maybe even close and reload MoI. (not quite sure).
In my yarn knit node, the Curve U version had end tangents which were (slightly) not parallel to the xy plane, (z values differed).
The InterpCurve U version of the knit curve, the end tangents were of constant z, which enables array in the xy plane with smooth end connections.
Edit, modified points.js file deleted. (MO says he will use it.)
I have switched to the Curves>curve node, as per MO
EDITED: 29 Dec 2024 by BEMFARMER
11614.35 In reply to 11614.34
Hi Brian
Thanks, I'll add it to the next version.
But generally, it's better to use the "Curves/Curve" node to generate curves from point data whenever possible.
"Curves/Curve" node supports both "control Points" and "Through Points" (interpCurve) modes + "Closed" option.
11614.36 In reply to 11614.35
Thankyou MO.
I will have a look.
I spent some time improving my Yarn node.
There are some new features in NodeEditorPlus that are terrific!
Especially:
1. Node to Macro,
2. Arrange Graph,
3. Notes. (Can be used as a label for the node assemblage, and for information.)
(See Documentation pdf)
Add Group could use some Documentation. How to remove "Group" box? ( > Edit Group > Remove Group.)
The use of the above improvements are for the most part self-evident., and the documentation helps.
Notes could use a documentation write-op. I had to type the same notes 5 times before realizing that (a very rapid) right mouse click adds them to the box. Otherwise the Info box resets.
A second shortcut key can be set up in MoI, to open a second canvas, to assist node program (assemblage) creationg.
11614.38 In reply to 11614.37
Hi Brian
Here is a shortcut while editing notes:
Press CTRL + ENTER to apply changes.
Also, clicking on the node box and mouse leaving the text area will apply the changes.
I can confirm that when mouse enters or leaves the node box it resets the changes before applying them. I can fix that.
>> A second shortcut key can be set up in MoI, to open a second canvas, to assist node program (assemblage) creation.
ALt + Click on the "New" button to open a new NE window.
Cool we can Open the 2 node Editors in the same time! ;)
11614.40 In reply to 11614.38
@Mo_Te
Have you make something for an easy translating ? (files, tables ... or nothing special like Max Smirnov :)
Edit: found the file lang.js and Compatibility.js but....
Here the ancient Elephant in French! :)
EDITED: 30 Dec 2024 by PILOU
Why vector and not Vector ?
My Moi French Site
11614.42 In reply to 11614.40
Hi PILOU
I haven't changed the translation process that much, it uses the "lang.js" as a dictionary.
Example: "English Word":"Translated Word",
I think you can translate almost every word you see in the NE plus. ( Except the node tooltips and searchbox )
That includes:
All menus, submenus, node title, node's inputs/outputs label and ui buttons
11614.43 In reply to 11614.42
Yep i have made that for the first Elephant but not yet refound the exact process!
I must be patient! :)
There is something wrong somewhere
That works fine for the "Elephant" but not for the "Plus"
All stays in English! Of course i change the language in the Options!
Elephant
​moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
NodeEditorPlus
var theme = 'Default'; /* Theme options: Default,Light,SkyBlue,Autumn,Lavender */
var language = 'FR'; /* Language options: EN,RU,FR */
moi.ui.createDialog( 'moi://appdata/NodeEditorPlus/index.html?scheme='+theme+'&lang='+language+'', 'resizeable,defaultWidth:870,defaultHeight:480', moi.ui.mainWindow );
Ok Found : I must write var language = 'FR'; and not var language = 'EN'; inside the 3 lines above! :)
And of course I must now add all that is not present in the "Lang.js" like "Interpolate" for "Interpoler" etc...
Works like a charm!
Need some time for modify, add, verify, complete all things! :)
EDITED: 31 Dec 2024 by PILOU
RotarySwitch node, (Widget > SwRotary), is now updated.
The .js should be placed in the extensions directory.
Testing was done by inputing numbers 1 through 6 as constant inputs to the switch, and the output connected to the Knit node at the Cycles input.
Run the Knit node, observe the MoI screen, click on the rotary switch, and see progressively, 1 or 2 or 3 or ... 6 Knit stitches.
The other Multi-modes pointarray and object... were not tested.
Is there a node which can be used for testing, which would display switch setting results, for any of the three Multi-modes?
The switch has Cycled and TicTac modes.
Even though the node is rectangular, the switch mimics a round multi select switch, with a knob.
Cycled mode mimics continuing clockwise rotation of the know.
TicTac mode mimics reversal of the clockwise rotation, for "countdown."
Widget SwDPDT node was also updated, but has not been tested yet.
Deleted swRotar.js
See Post 56 for MO's improved version of swRotary.
(TestRotarySwitch attached file will need fixup.)
EDITED: 4 Jan 2025 by BEMFARMER
11614.46
Here is a list of words that can be translated. (Menus, ui buttons, node titles, node input/outputs)
Translated word should be on the right side.
Edit: Use the complete list on this post:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11614.55
EDITED: 9 Jan 2025 by MO_TE
Damned I start without your file! :) (crossing post!
So I will made a blend of it and the actual existing lang.js! ;)
Start of a long way to go! :)
My Moi French Site
11614.49
Hi Mo or Michael,
Thank you so much for your amazing work! I hope more people will dive in and contribute to developing Nodeeditorplus!
I opened the .zip file you uploaded, copied the 'NodeEditorPlus' folder, and pasted it into: C:\Users\user_1\AppData\Roaming\Moi.
Next, I created a shortcut key 'Ctrl+Alt+N' and used the following script to launch it:
script: moi.ui.createDialog( 'moi://appdata/NodeEditorPlus/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
Everything seems to be working fine so far, but I figured it wouldn’t hurt to double-check—have I done this correctly?
Edit: Also Michael, I noticed it was not possible to create "Ctrl+Space" short key! is that correct?
- Psygorn
Here are a few rough notes documenting NodeeditorPlus, which could be added to the Documentation pdf.
I find it very difficult to write understandable documentation, and so tend to write in a verbose manner.
NodeeditorPlus documentation (rough notes 1/2/2025):
The General submenu is a collection of Multitype nodes.
The 4 types are described in MO's documentation pdf.
Input data is combined by Bundle node, or Concat node. The node is set to one of the four Types, (modes).
Each input slot receives data that is an array of elements corresponding to the mode.
Many input slots may be added to these nodes.
The difference between the Output of these two nodes is describe as follows:
In pointarray mode, the difference between Bundle and Concat is in the order in which the inputs are combined in the Output.
Concat (concatenate) takes a pointarray (input1), and adds (appends) a second pointarray (input2), and places the combined array into the output. (Additional inputs are also appended.)
Bundle takes the first point of the first pointarray (input1) and then the first point of the second pointarray (input2) and places them into the output array - and so on. So you can create e.g. points on different curves, bundle them and draw new curves across the base curves. (abstracted from Karsten, 2019)
An alternate explanation, considers the input data to be in a spreadsheet or matrix layout, where each cell contains an Element. Each node input is a "Row" array of Elements.
Concat outputs row1, followed by row2, ..., rowLast. This output is a concatenated array.
Bundle outputs the "Columns" (slices). row1_Element1, row2_Element1, ..., rowLast_Element1, then row1_Element2, row2_Element2, ..., rowLast_Element2,then, ...row1_LastElement, row2_LastElement,..., rowLast_LastElement. The output is an array.
Documentation on the Notes node:
Ctrl+Enter Set the text entries, or else they disappear.
Notes node can also be used as a title to the node assemblage, and brief documentation.
Text node can have text of point coordinates typed in, and then the node will output the point data.
For example, for x1 = 0.00, y1 = 0.39, z1 = -0.20, for the first row, type in 0.00 0.39 -0.20,
In the following pattern (do NOT type the text xi yi zi):
x1 y1 z1
x2 y2 z2
x3 y3 z3
etc
The pointarray output can be fed to the Interpolate node and/or the ConvertPts node, to display points, interpolated points, or curves.
Add another canvas:
Alt+New
ps
I did some testing of the swRotary node, in 3 of the modes.
It appears to function well.
I did manage to lock up the swRotary node, (somehow), in pointarray node, when only one input was hooked up, with switch set to a blank input.
EDITED: 3 Jan 2025 by BEMFARMER
Show messages:  1-10  11-30  31-50  51-70  71-90  91-110  111-120
