NodeEditor Plus [Unofficial]
 1-4  5-24  25-44  45-64  65-84  …  105-120
Hi all,
I will prepare a french version of the documentation.
11614.26 In reply to 11614.25
Excellent i will put a link to my French site!
EDITED: 25 Dec 2024 by PILOU
11614.27
Hi MO,
It is great to see a reboot of the Node Editor for MoI!
Thank you!
Wayne
11614.28
Hi
Just uploaded new version
v0.7.01 Updates:
Fixed pdf shortcut code issue
Added CTRL + Double click on canvas to toggle "canvas info" on and off
11614.29 In reply to 11614.25
Hi Phiro
Thanks for your contribution :)
Hi all,
A french version of the documentation.
Have fun !
P.
11614.31 In reply to 11614.30
Bonjour Phiro
Thank you for your contributions... which make this software magical and a forum rich with great people.
Merci pour vos contributions ... qui rendent ce logiciel magique et un forum riche de belles personnes.
chri
EDITED: 26 Dec 2024 by CHRI
Is beautiful that please without concept! My Moi French Site "http://moiscript.weebly.com
Note that old node programs, (assemblages of old nodes), may open and work in NodeEditorPlus, but they may look different, and inherit some differences from the new node.
Example: ConvertPts from an old node program. Mode order is different, but it still functions. Opening the new, Plus version shows different input and output.
I did an update of ConvertPts2, (it had some harmless errors as well, and was not multitype), to do interpcurve curves rather that control point curves, and called it ConvertPts3. It would go in the extension folder. (not uploaded) . Interpcurve could be added to ConvertPts, in the points.js big file.
EDITED: 28 Dec 2024 by BEMFARMER
11614.34 In reply to 11614.33
Here is a modified points.js file, as points.zip, which adds interpcurve to ConvertPts, as InterpCurve U, and InterpCurve V. (For NodeEditorPlus)
If desirable, this would replace points.js in NEPlus.
I'll leave it up to MO, whether to adopt this modification or not, and will delete this file for room, in a few days, either way.
I had to be extremely careful to spell the new words correctly. Failure for spellings to agree yields strange results, orange lights, etc.
Curve V and InterpCurve V just made a bunch of points in a pile in my test script.
I think that to re-used old node program assemblages, all nodes in them should be replaced with NEPlus version, even if they "look right".
Re-save the upgraded node program. Maybe even close and reload MoI. (not quite sure).
In my yarn knit node, the Curve U version had end tangents which were (slightly) not parallel to the xy plane, (z values differed).
The InterpCurve U version of the knit curve, the end tangents were of constant z, which enables array in the xy plane with smooth end connections.
Edit, modified points.js file deleted. (MO says he will use it.)
I have switched to the Curves>curve node, as per MO
EDITED: 29 Dec 2024 by BEMFARMER
11614.35 In reply to 11614.34
Hi Brian
Thanks, I'll add it to the next version.
But generally, it's better to use the "Curves/Curve" node to generate curves from point data whenever possible.
"Curves/Curve" node supports both "control Points" and "Through Points" (interpCurve) modes + "Closed" option.
11614.36 In reply to 11614.35
Thankyou MO.
I will have a look.
I spent some time improving my Yarn node.
There are some new features in NodeEditorPlus that are terrific!
Especially:
1. Node to Macro,
2. Arrange Graph,
3. Notes. (Can be used as a label for the node assemblage, and for information.)
(See Documentation pdf)
Add Group could use some Documentation. How to remove "Group" box? ( > Edit Group > Remove Group.)
The use of the above improvements are for the most part self-evident., and the documentation helps.
Notes could use a documentation write-op. I had to type the same notes 5 times before realizing that (a very rapid) right mouse click adds them to the box. Otherwise the Info box resets.
A second shortcut key can be set up in MoI, to open a second canvas, to assist node program (assemblage) creationg.
11614.38 In reply to 11614.37
Hi Brian
Here is a shortcut while editing notes:
Press CTRL + ENTER to apply changes.
Also, clicking on the node box and mouse leaving the text area will apply the changes.
I can confirm that when mouse enters or leaves the node box it resets the changes before applying them. I can fix that.
>> A second shortcut key can be set up in MoI, to open a second canvas, to assist node program (assemblage) creation.
ALt + Click on the "New" button to open a new NE window.
Cool we can Open the 2 node Editors in the same time! ;)
11614.40 In reply to 11614.38
@Mo_Te
Have you make something for an easy translating ? (files, tables ... or nothing special like Max Smirnov :)
Edit: found the file lang.js and Compatibility.js but....
Here the ancient Elephant in French! :)
EDITED: 30 Dec 2024 by PILOU
Why vector and not Vector ?
My Moi French Site
11614.42 In reply to 11614.40
Hi PILOU
I haven't changed the translation process that much, it uses the "lang.js" as a dictionary.
Example: "English Word":"Translated Word",
I think you can translate almost every word you see in the NE plus. ( Except the node tooltips and searchbox )
That includes:
All menus, submenus, node title, node's inputs/outputs label and ui buttons
11614.43 In reply to 11614.42
Yep i have made that for the first Elephant but not yet refound the exact process!
I must be patient! :)
There is something wrong somewhere
That works fine for the "Elephant" but not for the "Plus"
All stays in English! Of course i change the language in the Options!
Elephant
​moi.ui.createDialog( 'moi://appdata/nodeeditor/index.html', 'resizeable,defaultWidth:680,defaultHeight:420', moi.ui.mainWindow );
NodeEditorPlus
var theme = 'Default'; /* Theme options: Default,Light,SkyBlue,Autumn,Lavender */
var language = 'FR'; /* Language options: EN,RU,FR */
moi.ui.createDialog( 'moi://appdata/NodeEditorPlus/index.html?scheme='+theme+'&lang='+language+'', 'resizeable,defaultWidth:870,defaultHeight:480', moi.ui.mainWindow );
Ok Found : I must write var language = 'FR'; and not var language = 'EN'; inside the 3 lines above! :)
And of course I must now add all that is not present in the "Lang.js" like "Interpolate" for "Interpoler" etc...
Works like a charm!
Need some time for modify, add, verify, complete all things! :)
EDITED: 31 Dec 2024 by PILOU
Show messages:  1-4  5-24  25-44  45-64  65-84  85-104  105-120
