NodeEditor Plus [Unofficial]
 1  …  62-81  82-101  102-120
11614.102 In reply to 11614.101
Yep I must finish the first draw!
It's yet a miracle that all is working! :)
11614.103 In reply to 11614.102
Tutorials please :D
11614.104 In reply to 11614.103
For you the English version is yet ready! :)
https://moi3d.com/forum/messages.php?webtag=MOI&msg=11614.1
and after some tutorials https://moiscript.weebly.com/biblio-elephant.html French / English
EDITED: 30 Dec 2025 by PILOU
Last version of the Lang.js (French) till line 2985.... and it's working! :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/lang.zip
@MO_TE
Does the tooltips are yet ready in the English Version and how to see them on the screen of NodEditorPlus?
something to enable ?
Because seems to see them in orange previously!
Another thing : does i must Copy Past lines 2983 - 4157 and put FR
then Translate
or just change EN to FR line 2983 ?
then translate ?
EDITED: 1 Jan by PILOU
11614.107 In reply to 11614.106
Thank you for your contribution to the French translation.
Node tooltips are accessible via holding Alt and left-clicking on the node.
>> do i must Copy Past lines 2983 - 4157 and put FR
>> then Translate
You can leave them as they are; They are not for translation. thank you.
11614.108 In reply to 11614.107
THx for the Infos!
My Moi French Site
Yep but i can make that! ;)
Ps Seems thats working also fine with the French version !
You right all is yet fine i don't know why! :) (French Tooltips also) D:)
For a little test... transform a cube to a pyramid ... as the direct generation of the file don't yet works
Here the manual method not sure that really help! :)
1. Create the Base Shape ... Add a Curve/Rectangle node.
Set Width to 20 and Height to 20.
This represents the footprint of your shape on the ground.
2. Elevate the Top Profile... Add a Transform/Move node.
Connect the Rectangle output to the Objects input of the Move node.
In the Translation field, set the Z value to 30 (format: 0,0,30). This defines the height.
3. Control the Taper (The "Magic" Step) ...Add a Transform/Scale node.
Connect the Move output to the Objects input of the Scale node.
Crucial: Set the Center of the Scale node to 0,0,30 (the same height as your moved square).
Add a Basic/Slider node. Set its range from 0.0 to 1.0.
Connect the Slider output to the Factor input of the Scale node.
Slider at 1.0 = Cube
Slider at 0.0 = Pyramid
4. Group the Profiles... Add a Logic/BundleArray node.
Connect the original Rectangle (from Step 1) to In 1.
Connect the Scale output (from Step 3) to In 2.
This creates a list containing both the bottom and top squares.
5. Generate the Volume...Add a Construct/Loft node.
Connect the BundleArray output to the Profiles input.
MoI3D will now stretch a "skin" between the two squares.
6. Final Output... Add a Basic/Output node.
Connect the Loft output to it to see the final geometry in the MoI3D viewport. ...
Quick Tip: If you want the pyramid to be "solid" (a closed BREP),
make sure to check the "Cap ends" option if it's available in your version of the Loft node, or use a Solid/PlanarSrf on the result.
Curious result ... but surely schematic
a node Object / Selected don't exist anymore ?
Waiting more something like that! :)
But not yet tested because it's while i don't touch this sort of thing!
But terrific if you can ask an Ia to make for you anything you want without knowledge of Nodes!
Maybe not today at 100% but surely after tomorrow!
EDITED: 2 Jan by PILOU
11614.113
Generating an object in NodeEditor is quite similar to how it's done in moi, but with parametric capabilities.
Here are two simple methods to generate a pyramid.
This node has been relocated to the "Select" menu, under the title "Select Scene Objects". It's also accessible in the search box.
Size: 24.9 KB, Downloaded: 40 times, Dimensions: 501x237px
Size: 192.2 KB, Downloaded: 41 times, Dimensions: 1094x600px
Size: 32.3 KB, Downloaded: 36 times, Dimensions: 271x375px
11614.114 In reply to 11614.113
Excellent! Where is the Search Box ? (how to call it ?
Center ?
11614.115 In reply to 11614.114
Double-click on the canvas (NodeEditor window) :)
11614.116 In reply to 11614.115
That is wortking!
11614.117
Great Work MO!
// Rich
11614.118 In reply to 11614.1
Hi Mo,
been playing with your unwrap curve / surface node.
Have you an example as getting shapes that need scaling so not sure I am using it correctly.
Barry
Works as aspected! Sorry in French but...
Pinky curve is planar and has same length than green one!
It's the same for you ?
Curious! https://moiscript.weebly.com/uploads/3/9/3/8/3938813/planar_curves.3dm
EDITED: 15 Jan by PILOU
11614.120 In reply to 11614.119
this is why I am not sure if I am using it correctly.
The unwrapped in these cases are 1 x 1 but if scaled looks correct.
In others they are scaled correctly in one direction only.
Barry
EDITED: 15 Jan by BARRY-H
Show messages:  1  …  42-61  62-81  82-101  102-120
