NodeEditor Plus [Unofficial]
 1-9  10-29  30-49  50-69  …  110-120
11614.10 In reply to 11614.1
Great work Mo, thanks for sharing it!
11614.11 In reply to 11614.7
Hi Brian
>> it loaded into the old NE program, but the new function datatype inputs showed up, and the nodes were Red, and program would not run.
As I mentioned before, some of the new features of this version are not supported in the older version.
For example, string type, widgets like button and toggle, and so many node relocation. So that's normal if older version fails to load files of this version.
>> The shortcut resizable window setting of the new version does NOT seem to work.
>> perhaps MO can comment. :-)
Sorry. I have no idea, It works fine for me here. :)
11614.12 In reply to 11614.10
Thanks Michael :)
11614.13 In reply to 11614.11
Thanks MO,
Here at home, still on Windows 10.
I'll try it at work tomorrow, (Windows 11).
Thank you very much for this new nodeeditor.
11614.14 In reply to 11614.6
Is there any error message displayed?
If you get an error dialog that says "ReferenceError: Can't find variable: theme" then it probably means you only got the last line (starting with "moi.ui.createDialog") copied, make sure you copy all 3 lines.
11614.15 In reply to 11614.6
for this part:
> Edit upon closing and re-opening MoI, the New shortcut key is no longer installed
> (assigned new code)...so it does not work.
This can happen if you have multiple instances of MoI running when you set up a new shortcut key.
MoI will save shortcut keys to the moi.ini file when it exits, and if you exit an instance that did not have the shortcut key set in it last it will get overwritten.
So it's good to have only one instance of MoI running when you are setting up shortcuts, and then close that one before you open up any more.
I've tuned this up a bit for the next beta so that it will write changes to the moi.ini immediately after editing any shortcuts. You should still have only one instance running but you won't need to close it to get moi.ini to be updated.
11614.16 In reply to 11614.14
I have tried numerous permutations of changing the Shortcut key. Including Alt+T, Ctrl+Alt+T, Ctrl+Alt+X, and rebooting the computer.
Setting Alt+T to my modified code, I am able to get Light, and Lavender.
For the PDF specified shortcut code, I am now "stuck" on default dark theme, but with the large canvas. A while back the canvas size was remaining small.
Setting Ctrl+Alt+T to the PDF specified shortcut code, with copy & paste, numerous times, and changing the Default theme to Light, or Lavender, etc, does NOT change from default Dark.
After a reboot, the canvas display is delayed, with a very brief flash of light color.
It is almost like there is a Cache of the default dark theme, but reboot should end this. (?)
(I was able to change the default language to FR, with no problem.)
Anyway, weird stuff. (Windows 10)
I do have the recent new alternate Themes installed, but am not using them.
Is anyone else having NodeeditorPlus Theme problems?
Theme problem SOLVED!
I was copying the shortcut command from a PDF program which opened the NEPlus document PDF file.
Apparently the PDF program put in some BAD characters of some sort.
So copying the shortcut code from MO's code on the MoI discussion worked fine.
I think that the PDF reader program was from MS Edge(???)
11614.18 In reply to 11614.17
With further testing, I'll conclude that "Copying the Shortcut code from the PDF documentation via Edge, Google chrome, or Adobe does NOT work properly, even though the characters visually appear correct.
Copying from the MoI forum works.
I suppose that typing the pdf code manualy would probably work.(?)
11614.19 In reply to 11614.18
I'm glad you got it figured out Brian!
11614.20 In reply to 11614.8
Hi Mo,
Perhaps the option to toggle on and off the time elapse could be added to the node menu?
Barry
11614.21 In reply to 11614.20
Hi Barry
It is possible, but I think It's not something that we need to access all the time in a menu.
I'll think about it.
After separately copying the 4 shortcut code lines from the Documentation PDF, to Notepad++, and removing the CR and/or LF (Carriage Return, Line Feed), at the ends each code line, by backspacing, I have reached the following conclusion:
The Documentation PDF shortcut code contains several CR and/or LF, which if copied to the shortcut key, cause the shortcut code to fail.
I would suggest changing the PDF to not create CR and/or LF, (if possible), OR add a text file of the shortcut code, to the NodeEditorPlus zip file, and tell the user NOT to copy/paste original PDF code.
Edit: CR and/or LF can be removed in Notepad++, (find and replace), per internet searches.
I am now done with this shortcut topic :-)
EDITED: 23 Dec 2024 by BEMFARMER
11614.23 In reply to 11614.22
Thanks for mentioning it. I can see it now.
The problem was at the end of the third line. I should have concatenated the 3rd and 4th lines in the pdf.
var theme = 'Default'; /* Theme options: Default,Light,SkyBlue,Autumn,Lavender */
var language = 'EN'; /* Language options: EN,RU,FR */
moi.ui.createDialog( 'moi://appdata/NodeEditorPlus/index.html?'+
'scheme='+theme+'&lang='+language+'', 'resizeable,defaultWidth:870,defaultHeight:480',
moi.ui.mainWindow );
The code in my first post works fine, I'll update the pdf soon.
Sorry for inconvenience.
11614.24 In reply to 11614.23
Cool MO!
Thank you again
Hi all,
I will prepare a french version of the documentation.
11614.26 In reply to 11614.25
Excellent i will put a link to my French site!
EDITED: 25 Dec 2024 by PILOU
11614.27
Hi MO,
It is great to see a reboot of the Node Editor for MoI!
Thank you!
Wayne
11614.28
Hi
Just uploaded new version
v0.7.01 Updates:
Fixed pdf shortcut code issue
Added CTRL + Double click on canvas to toggle "canvas info" on and off
11614.29 In reply to 11614.25
Hi Phiro
Thanks for your contribution :)
Show messages:  1-9  10-29  30-49  50-69  70-89  …  110-120
