Custom theme tweaks & questions
All  1  2-11
11613.2 In reply to 11613.1
Hi aphaits,
For the first 3:
> 1. Is there a way to change the style / color / icon of the window top part?
That part is drawn by the operating system, there isn't anything set up in MoI to customize it.
> 2. Is there a way to change the style / color / icon of the horizontal & vertical scroll bars?
Most of the scroll bar pieces will use the PushButton colors. But there are a couple of scrollbar areas that don't have a theme symbol set up for them, they can be adjusted in the theme's moi.css . If your theme was based off the regular dark theme, there should be scroll bar stuff in your theme's moi.css , look for:
::-webkit-scrollbar-corner {
background-color:#444;
::-webkit-scrollbar-track-piece {
background-color:#777;
> 3. Which does the progress bar color affects the GUI? Can’t seem to find it.
It's shown in the upper right area of the window when loading in a large file.
Try this - type Tab so that keyboard focus goes into the XYZ control in the bottom toolbar and then paste in this:
script: moi.ui.sidePane.document.body.insertAdjacentHTML( 'afterBegin', '<moi:ProgressBar id="progress_test">'); moi.ui.findElement( 'progress_test' ).value = 25;
That will insert a progress bar element at the top of the side pane so you can see it.
Other answers to follow in a bit...
11613.3 In reply to 11613.2
Thank you for the help, Michael!
The progress bar and scrollbar looks great now!
EDITED: 20 Dec 2024 by APHAITS
Size: 17.9 KB, Downloaded: 131 times, Dimensions: 577x229px
Size: 110.9 KB, Downloaded: 153 times, Dimensions: 1065x969px
11613.4 In reply to 11613.1
Hi aphaits, for #4:
> 4. Can these icons be compacted into a group icon with a dropdown list of aligns options?
It would be difficult to do that with the theme mechanism, but you can do it by modifying the script that is generating that UI.
If you go to your appdata startup folder, there should be a script there named "Align Buttons.js" which is what makes those align buttons.
If you replace it with the attached version, it will instead make one "Align" menu button which will show the 6 align types in a popup menu.
For #5:
> 5. Can these icons be changed? Can’t seem to find it anywhere.
These are from the CustomUI mod which consists of script files inside the appdata startup folder.
The icons are set up as embedded data inside the script file.
See here for how to change it so it will get the icon from a .png file instead:
https://moi3d.com/forum/index.php?webtag=MOI&msg=11577.2
EDITED: 21 Dec 2024 by MICHAEL GIBSON
11613.5 In reply to 11613.1
Hi aphaits, re #6:
> 6. Is there a way to change the size and font style?
Do you mean just for the Scene Browser or do you mean for everything?
If you want to make just the Scene Browser text a little bit smaller than the regular text size, put this into your theme's moi.css :
moi\:SceneBrowser {
font-size:80%;
11613.6 In reply to 11613.5
perfect! the scene browser text is a bit too big sometimes when you have long titles for some objects names
The 80% setting you setup is great!
Size: 49.8 KB, Downloaded: 139 times, Dimensions: 376x694px
11613.7 In reply to 11613.4
The align foldering works great!
one thing though, the spacing between the align button and the rest of the buttons seems oddly close
11613.8 In reply to 11613.7
Hi aphaits,
I've updated it so it puts in a spacer before the align button, please re-download it and see if it's better now.
11613.9 In reply to 11613.8
Perfect!
11613.10 In reply to 11613.4
The icon replacement works like a charm!
Doing some final minor tweaks and I will upload the theme here when tweaks are done.
Thank you again Michael for the helpful directions!
11613.11
Alright, been using this for a couple days and also had some nice holiday. So far no problems and emulates blender's look quite well.
Here's the theme files, try it out and let me know which parts is buggy or looks wrong. Enjoy!
PS: Additional icons are in another zip for several scripts and plugins not included in basic Moi 3D install.
Show messages: All  1  2-11
