Unit Length settings, General versus Dimensions
All  1-4  5-6
11612.5 In reply to 11612.4
>The second "General" should have been DIMENSION setting...
> > If General is set to centimeters, the DIMENSION setting of ft & inches shows inch measurements. So does
> > one setting override the other?
Yes, dimensions have their own individual formatting properties.
If the dimension has Distance display: "Feet & Inches" set, it will display a feet & inches value regardless of the current model units (except for "No unit system").
Please let me know if you still have a question on this area.
11612.6 In reply to 11612.5
I believe that I now understand that the Fractional display, (for Feet & Inches), incorporates Rounding.
In the Object properties popup, and the Options > Dimensions box, a suggestion would be to change the label "Fractional display:", by adding the word "rounding", or "rounding precision".
Or the word or words could be added after the fraction selection box. (???)
Show messages: All  1-4  5-6
