Navigating workspace using the touch pad
All  1  2-5
11610.2 In reply to 11610.1
Hi Elang, is it a Mac or Windows laptop?
For Mac with the trackpad you can do:
Two fingers dragging = Pan
Ctrl + Two fingers dragging = Rotate
Pinch = zoom
Two fingers double tap ("Smart zoom") = View reset
These all work with light skimming touches, not a "click".
There are some options you can adjust under Options > View > Rotate/Pan/Zoom options > "MultiTouch options".
If you want to have plain 2 fingers to be rotate and Ctrl to be Pan set the checkbox there for "Swap 3D rotate and pan".
There is also a ReverseTrackpadScroll=n option in moi.ini .
You might also be able to get 3 fingers dragging to be used for rotate if you can get the operating system to not eat it, some info here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=5774.50
https://moi3d.com/forum/index.php?webtag=MOI&msg=6339.5
EDITED: 17 Dec 2024 by MICHAEL GIBSON
11610.3
Hi, Michael...
It's for Windows 10. Very sorry not to mentioned it earlier.
And I'll look into your direction ASAP.
Thank you.
EDITED: 17 Dec 2024 by ELANG
11610.4 In reply to 11610.2
Hi Elang, on Windows the touch pad isn't used for multi-touch type navigation. However if the screen is touch capable you can do multi-touch actions on the screen.
11610.5
Understood, Michael.
However, I can confirm that the two finger gestures and pinching works for zoom in & out on Windows.
Thank you very much.
Show messages: All  1  2-5
