How di I fix this? open curves
All  1-3  4-5
11604.4 In reply to 11604.3
When several identical curves are "on top of each other", it is difficult for the program to determine how to connect the lines correctly, which is why this result is obtained.
Fonts often suffer from this disease. There was a cure for this somewhere on the forum.
https://moi3d.com/forum/messages.php?webtag=MOI&msg=11111.1
EDITED: 3 Dec 2024 by WN
11604.5 In reply to 11604.3
Hi Matadem,
> Question...shouldn't removeduplicates work also?....I can never seem to make it work :/
RemoveDuplicates compares curves with other curves, it doesn't try to detect duplication in a single curve that backtracks over itself like you have here.
If you use Edit > Separate to break them apart then RemoveDuplicates can work here.
Show messages: All  1-3  4-5
