Open edge problem with exported STL
All  1-2  3
11597.3 In reply to 11597.2
Export: I typically select the object(s) to export and then use FILE/EXPORT and then choose STL for the file type.
Stray objects: Looks like the 'stray objects' you identified were likely a couple of the fillets that appeared visually to be okay but apparently failed to properly attach. Seems these two strays somehow remained associated with the AZ 3D print bracket when I selected the bracket object for export.
I don't recall seeing any MOI3D failure warnings re these two stray fillets, but again could likely be another user error here. I typically only use the default fillet settings. If you need more details please let me know.
Thank you for the Meshing Options recommendation. I'll definitely pay more attention to the visual going forward and attempt do a better job with the triangles. My expertise selecting the optimum mesh parameters are novice at best. Another area where some additional study seems to be warranted.
Thanks again as always for MOI3D!
Scott
Show messages: All  1-2  3
