how to determine angle between 2 planes
All  1-6  7-9
The angle between two planes is determined by the angle between the normals of the two planes.
https://www.cuemath.com/algebra/angle-between-two-planes/
https://byjus.com/maths/angle-between-two-planes/
I do not know which MoI commands would yield the surface normal of a plane.
Some clues here:
https://moi3d.com/forum/messages.php?webtag=MOI&msg=9581.321&highlight=yes
11584.8 In reply to 11584.7
Here's a script that can be pasted into a shortcut key, preselect 2 planar faces before running it. It will report the angle between the plane normals.
script: var faces = moi.geometryDatabase.getSelectedObjects().getFaces();
if ( faces.length == 2 && faces.item(0).isPlanar && faces.item(1).isPlanar )
	var A = faces.item(0);
	var B = faces.item(1);
	nA = A.planarFrame.zaxis;
	nB = B.planarFrame.zaxis;
	var dot = (nA.x * nB.x) + (nA.y * nB.y) + (nA.z * nB.z);
	var angle_radians = Math.acos( dot );
	var angle_degrees = angle_radians * 180.0 / Math.PI;
	moi.ui.alert( moi.ui.formatNumber(angle_degrees) );
else
	moi.ui.alert( 'error - 2 planes not selected' );
Cool....
"Confirmation of my method "Line Line" :)
Plan A Plan B
Select All
Line Line from Plan A at the origine (2 Line Line)
A Triangle (with 2 rectangles 3 pts) "Line Line" to an axe
Rotation to Plane
You have the Angle!
EDITED: 5 Nov 2024 by PILOU
Show messages: All  1-6  7-9
