Fatlines quirk
All  1-2  3-10
11583.3 In reply to 11583.2
Here 'tis:
Not sure why the file should apparently be so big?
11583.4 In reply to 11583.3
Works like a charm as expected! ;)
And if i save the 2 new curves i have same size than yours...
EDITED: 4 Nov 2024 by PILOU
11583.5 In reply to 11583.4
Perhaps there's something in the way I've set it up? I'm using the latest version of Fatlines in v4 - it worked perfectly in v3...
11583.6 In reply to 11583.3
Hi Raven, thanks - for this part:
It's because there's an embedded background image file. If you go to View > Image and remove it that will make a much smaller file.
11583.7 In reply to 11583.6
Must've been mistakenly included in my template - thanks for pointing that out :)
EDITED: 4 Nov 2024 by 777RAVEN777
11583.8 In reply to 11583.4
Hi Frenchy - were you able to get this work sensibly? ;)
11583.9 In reply to 11583.8
Without any problem since many years! :)
For any funny things!
11583.10 In reply to 11583.8
Hi Raven, thanks for posting the file. Yes the difference comes from Fatlines using Offset in rectangular mode and Flow in pointy mode.
The start direction using flow can be arbitrary but it should behave better if you put the curves on the Top viewport XY plane instead of Front view XZ plane.
Show messages: All  1-2  3-10
