v4 CustomUI
All  1-3  4-7
11576.4 In reply to 11576.3
Just one more question - I notice some folks have sub-folders in their libraries - does this version support that? If so, how are they set up?
Cheers :)
11576.5 In reply to 11576.4
HI Raven, it doesn't support sub folders but it does support having multiple library folders.
To enable that there is a file "ObjLibrary.cfg.htm" to edit inside the %appdata%\Moi\customui folder.
It starts out with this:
Object Library;MOI\objects
You can add a line to set up additional library folders, like this:
Obj lib 2;MOI\objects2
That's display name first then a semi-colon then path. If you have a path with spaces in it you may need to put quotes " " around it.
Also the v5 beta supports displaying thumbnail images for .3dm files so you can just use the regular operating system file browser as an object library.
EDITED: 28 Oct 2024 by MICHAEL GIBSON
11576.6 In reply to 11576.5
Magic as always - thanks so much Michael :)
Is there a limit to how many library folders it will handle?
11576.7 In reply to 11576.6
Hi Raven,
Nope, no limit.
Show messages: All  1-3  4-7
