v4 CustomUI
All  1  2-7
11576.2 In reply to 11576.1
Hi Raven, the CustomUI .zip file is named CustomUI.2.0.beta2.zip .
When you unzip it, there will be 3 folders, "customui", "objects", and "startup".
These need to be copied into the MoI app data folder.
You can open the MOI appdata folder by typing Win+R to bring up the windows "Run" dialog and type in %appdata%\Moi that will expand to a folder like C:\Users\<Your user name>\AppData\Roaming\Moi
Copy the "customui" and "objects" folder from the .zip file into there, so you have %appdata%\Moi\customui and %appdata%\Moi\objects.
Then for the "startup" folder there will already be a folder for that in appdata so go into the startup folder from the .zip and copy all the contents of it into the already existing %appdata%\Moi\startup folder.
11576.3 In reply to 11576.2
Ah. I knew it was that simple.
Thanks again Michael :)
11576.4 In reply to 11576.3
Just one more question - I notice some folks have sub-folders in their libraries - does this version support that? If so, how are they set up?
Cheers :)
11576.5 In reply to 11576.4
HI Raven, it doesn't support sub folders but it does support having multiple library folders.
To enable that there is a file "ObjLibrary.cfg.htm" to edit inside the %appdata%\Moi\customui folder.
It starts out with this:
Object Library;MOI\objects
You can add a line to set up additional library folders, like this:
Obj lib 2;MOI\objects2
That's display name first then a semi-colon then path. If you have a path with spaces in it you may need to put quotes " " around it.
Also the v5 beta supports displaying thumbnail images for .3dm files so you can just use the regular operating system file browser as an object library.
EDITED: 28 Oct 2024 by MICHAEL GIBSON
11576.6 In reply to 11576.5
Magic as always - thanks so much Michael :)
Is there a limit to how many library folders it will handle?
11576.7 In reply to 11576.6
Hi Raven,
Nope, no limit.
Show messages: All  1  2-7
